NUT RING SS
Intro: NUT RING SS
OK now that I have your attention, get your mind out of the gutter!! LOL
What I want to show in this instructable is how I make a ring out of a Stainless Steel Nut. This idea was given to me from a co-worker who learned that I make jewlery and stuff during my off time.
STEP 1:
After you have found a nut that is close to the final size you want, you need to chose a pattern you want for your ring. I chose a simple signet type ring to make as it is simple and easy. I used a ultra fine perm. marker to draw the layout on the ring.
STEP 2:
Once you have your pattern drawn, get you handy rotary cutting tool, or hack saw if you perfer. Cut out your pattern, leaving a small amount of material. You can and will do more trimming as you go, but if you cut too much off on the first cuts then you will need to adjust the pattern or start over.
STEP 3:
After rough cutting you can follow up with files or your favorite rotary tool! I also trim the inside of the nut to fit on the finger I chose. It makes for a smooth fit inside to use a sand drum to remove the top of the threads.
STEP 4:
The first ring is rounded and smooth, the second is for my son. He wanted the "flats" to be left on. I just sanded the bumps off the side to make it comfortable to wear.
STEP 5: Final
The final step I polished the top down to 2000 grit wet/dry then cut a "V" into the top. I havnt cut the "V" into my son's yet. I wanted to show the two before I cut his.
15 Comments
Tobyag 7 years ago
What size nut did you use or was it trial and error?
ironsmiter 14 years ago
Before beginning work on the nut, Take a moment and drill out the threads.
With the flats still on, it'll be much easier to clamp in a vice, and the interior then starts smooth and concentric.
If it is for a particularly small finger, the threads can be left intact, and filled with epoxy. The machinist version of the nail polish ring fix! :-)
Before final polishing, consider doing some nice temper coloring. For real contrast, after coloring, you can sand/file/polish everything back to shiny silver, except the part you want to leave. I advise Blue heat color for guys, and a darker purple for te gals, but that's personal preference. MY choice would be a straw/bronze all over, with a blue lettering(do the purple, file/sand everything NOT to be purple, then re-color to bronze).
Keep up the fine work.
Hope your son enjoys his.
Achan20 13 years ago
ironsmiter 13 years ago
So, finish the ring how you'd like it.
Set your oven to whatever temperature/color you'd like to achieve.
Stick the ring on the oven rack, and wait a few hours.
If you set the oven right, it should color just right, and stay there indefinitely. When it gets there, just shut the oven off and let everything cool off, and you're done.
For Blades, I use a red hot bar of steel, and pass the work very near to it, sometimes even rubbing on the block. this lets me control where the heat is going. When the desired color is achieved, you must plunge the work into cold water. otherwise the heat will keep running, and it'll go too far, too hot, and ruin the temper, before air cooling sets in. Basically, this allows a bladesmith to leave the cutting edge of a blade nice and hard, while making the flats less brittle and more flexible.
Have a read over at http://www.tpub.com/steelworker1/11.htm I'm not a professional writer, and I find it MUCH easier to SHOW the technique than to describe it. And I think they may have done a much better job of it than I have.
vardamanj 13 years ago
Thanx,
NutandBolt 13 years ago
jtobako 13 years ago
lemonie 14 years ago
L
vardamanj 14 years ago
L
