NattyJane's Birds of a Feather Costume Tutorial
Intro: NattyJane's Birds of a Feather Costume Tutorial
For Halloween a few years ago I made a flamingo costume for myself and a parrot costume for my best friend. With Halloween just around the corner once more, here is a tutorial to get the bird costume inspiration flying!
STEP 1: Brainstorming
Choose your bird!
Flamingo, parrot, toucan, imaginary technicolor falcon! The possibilities are as endless as your imagination.
Choose your colors!
The easiest way to do this is to research your bird. Look through photos to help figure out the main colors that you will be using.
After looking at photos of flamingos I decided to use a light pink as my main color plus a darker pink, red, and white for the other feathers. For the parrot costume, I looked at photos of scarlet macaws which helped me to choose colors and see the placement of those colors on the wings.
At this point, you can also read about your bird for added costume enjoyment! Learn about where your bird is from, what it eats, and how it behaves in its' natural environment so that you can truly get into character once you're all dressed up!
Choose your fabric!
The edges of the feathers and wings are left unfinished, so try to pick something that won't fray too much. When looking at fabric, imagine how it will look as a finished wing. You will probably want something that moves, flows, and flaps nicely. Also, try not to choose anything too heavy since you will be sewing many layers of feathers to each wing.
For my costumes I bought inexpensive, lightweight polyester in bright colors with a satin finish.
Choose your colors!
Choose your fabric!
STEP 2: Creating the Wing Base
The main components of the bird wings are the feathers and the wing base, so let's start with the base. You will be creating two separate wing bases, one for each arm, both in the basic shape of a right triangle as shown in the photo.
In order to cut out your two wing base triangles, you will have to take some measurements:
Hold your arm out like you are flying and have a friend measure from the middle of your shoulder blades out to your wrist. This will be the top edge of the triangle (A).
Have your friend measure from the same spot between your shoulder blades down the middle of your back to the desired length for your wings. This will be the side edge of the triangle (B).
For the hypotenuse of the triangle, (C), I used a curved edge connecting the ends of (A) and (B), however you can make this line straight if you wish.
Now mark your triangle measurements onto your fabric and cut out your two base wing triangles. As a flamingo my main color was light pink, so I used pink fabric for my base wing triangles.
Once the wing base triangles are cut out you can fold in the edges twice narrowly to finish them if you would like. For my wings I cut edge (B) along the selvage of my fabric, narrowly hemmed edge (A), and left edge (C) raw.
STEP 3: Creating the Feather Template
To make the process of wing construction faster, the feathers are created in sets that are double layered. For my original costumes I used sets of four feathers in a row, which I will also use in this tutorial, but once you have the basic idea, you can change it around any way you would like for your wings. To cut even feathers of uniform size, we are going to create a paper feather template. Take two pieces of paper of equal size (here I am using standard 8.5''x11'' printer paper) and cut one in half, hot dog style as shown in the photo. Take one piece of the cut paper and set the rest aside.
STEP 4: Creating the Feather Template 2
Draw a line one inch down from the top edge.
STEP 5: Creating the Feather Template 3
Draw lines dividing the piece of paper into four equal sections. This paper is 11 inches long so each of the four sections will be 2 and 3/4 inches.
STEP 6: Creating the Feather Template 4
Draw in the feathers in each of your four sections making sure not to go past the top inch that was marked off earlier since you will be using the top edge to cut along a fold. Have fun with this step and play around with different shapes until you find one that you really love!
STEP 7: Creating the Feather Template 5
Cut around the edges to complete your feather template! At this point you could also transfer the template onto thin cardboard or card stock to make it more durable.
STEP 8: Cutting Out the Feathers
Get the full sheet of paper that we set aside earlier and use it to cut out a large rectangle. Using an iron, press the rectangle of cotton in half hot dog style.
STEP 9: Cutting Out the Feathers 2
Place your feather template on the pressed piece of fabric with the top edge along the fold and cut. I highly recommend using a rotary cutter for this step since it makes the process very quick.
STEP 10: Cutting Out the Feathers 3
And there you have it! A double layered feather set that is ready to be attached to the wing base triangle! Continue using your full sheet of paper and your feather template to cut out more sets of feathers! This part of the project is a bit repetitive and time consuming, but it is well worth it in the end. So turn on your favorite music and get lost in the feathers! Also, as you are working, try not to stress about cutting exactly from the template. Remember, the wings have many layered feathers and they don't all have to be perfect.
STEP 11: Sewing the Wings
Lay out your wing bases and begin by playing around with placing and layering your feathers. Do this without pinning the feathers down so that you have full freedom of movement to see what arrangement you like best. The placement of the feathers on the wing bases is completely up to your imagination, but I've put together a few tips in this tutorial that you can refer to. The above diagram maps out my general approach to layering the feathers in my original costumes. The bottom most layer is along the curved edge (C) and is positioned to stick out over the edge so that you can see it peaking out from the other side of the wing. The layers that follow slowly change from curved to straight since I wanted to finish with feathers running straight across the top edge (A). Also, on the top edge, I opened the double layered feathers up so that they would show on both sides of the wing.
STEP 12: Sewing the Wings 2
Above is a view of the back of the wing. Notice the layer along curved edge (C) peaks over, and the layer along the top edge (A) is showing by opening feather sets and placing each layer on either side of the edge. Also, the thread color should match your wing base color on this side so that your stitching isn't too noticeable.
STEP 13: Sewing the Wings 3
Try staggering each row of feathers to make the layering more effective and interesting. Remember that you don't have to use each set of feathers as a set of four. If you get to a spot that could only use two feathers, go ahead and cut a set in half to two feathers.
STEP 14: Sewing the Wings 4
Leave some space between each row. These blank spaces are covered with well placed staggering. Once you have figured out your general idea for layering, leave one wing base set up with the feathers in place as a guide, and begin sewing down feathers on the other wing base. Sew the feathers down row by row beginning along the curved edge (C).
STEP 15: Add Loops
Once all feathers are sewn down to your liking, sew on two loops of fabric to both wings, one on each end of the top edges (A).
STEP 16: Add Loops 2
The loop at the corner where the top edge (A) and the curved edge (C) meet is meant to help attach the wing to your wrist. I found it easiest to use old hair ties through these loops which slipped around my wrists easily when I was putting on the wings. The loop at the corner where the top edge (A) and the side edge (B) meet is meant to help attach the wings to your neck. Pass a ribbon through these loops on each wing, as shown in the drawing, and tie the ribbon around your neck. If this is uncomfortable, use the loops to pin the wings to your clothing instead.
STEP 17:
And there you have it! Two beautiful bird wings! So tie them on and start flapping!
Also, check out my blog for tutorials and other completed projects!
32 Comments
jramos47 4 months ago
DonnaS246 6 years ago
I am making this pattern for 4 year old ballerinas. The parrot costume is in red, orange and green wings. Would I cut 2 inch wing template or smaller
ColleenL26 7 years ago
Has anyone tried this with felt? Is it too heavy?
AmyC124 8 years ago
Has anyone tried this with sheer fabrics or lace? I'm trying to figure out the best way to create bird wings for a bird themed contemporary dance solo.
sarasimm 8 years ago
I am making these wings with a couple of old fabric shower curtains. I plan to use the top edge of one to be the top edge for my wings and there are already holes- so I don't have to add loops!
TaniaC7 8 years ago
I just made this costume for my almost 3 year old. Thank you so much for the wonderful, detailed tutorial, and beautiful idea.
RedSakura115 8 years ago
KarenC3 9 years ago
phlogistonly 9 years ago
Approx how much material did you use in total?
mduncan8 10 years ago
I used these for part of my owl costume.. I will have to get you the photo
jelenamitic77 10 years ago
mantill 10 years ago
Earthlove 10 years ago
Very Interesting 11 years ago
poofrabbit 11 years ago
HabibasBeloved 11 years ago
blossom9283 11 years ago
NattyJaneSews 11 years ago
Sherlock69 11 years ago
