Introduction: Nature Clock
I made this nature-themed clock. Since we are in the season of spring, I thought that this theme would be appropriate. I took a clock motor from an unused clock and used it to create this one. I also included sticks and leaves that I collected from my yard.
- Cardboard
- White Spray Paint
- Sharpie
- Clock Motor
- Clock Hands
- Leaves
- Sticks
- Scissors
- Hot Glue
- AA Battery
Step 1: Clock Face
I took a piece of a cardboard box and cut out a circle with a diameter of approximately 22.5cm to make the clock face. I spray-painted it white and drew the clock numbers in with a black sharpie. I also made a hole in the middle of the circle, where the clock motor will go through.
Step 2: Clock Motor and Hands
I took an old clock motor and clock hands and used them for my clock. I fit the clock motor through the hole made in the clock face and connected the clock hands to the motor. I powered the motor with a AA battery. This is what will indicate the time.
Step 3: Clock Frame
I found multiple sticks from my yard and used them to create the frame of the clock. I cut the sticks into smaller pieces and placed them around the clock face. Then I connected the sticks together with a hot glue gun.
Step 4: Clock Face Decoration
I took leaves from a bush and glued them near the center of the clock face. I took small leaves and placed them in between each of the numbers on the clock face.
