Introduction: Neo Pixel LED Digital Clock
In this project, I created a digital clock using WS2812b neo pixel LEDs. The digits are in 7 segment display format. I used acrylic sheets to make the enclosure.
Parts used:
  • Arduino nano x1
  • RTC module x1
  • WS2812b LED x30
  • Wires
  • USB cable to power/program/set time
  • Cardboard/Acrylic sheets to create enclosure and cut out 7-segments
  • Glue and tools as required
Step 1: Arduino Code
The challenge with the code was to illuminate the correct LEDs corresponding to different digits. I acheived this using pre-defined arrays for corresponding numbers.
You can download the code from the below link,
Github code of this project
Step 2: Wiring and Making Enclosure
Above is how I wired the LEDs. I cut out 7 Segment digits out of a card board. It will be easier if you can use a laser cutter.
