Introduction: Nerf Minigun Pistol!!!!!
I just got the best idea! Turn a Nerf Maverick into a minigun pistol! Since some of my previous mav mods didnt work, i figured i had nothing to lose. Heres how:
Step 1: Materialz ( I Alwayz Spell It With a 'z' )
You will need:
Nerf Maverick
Small crosshead (philips) screwdriver
Mini hacksaw
Hot glue gun
Nerf Maverick
Mini hacksaw
Hot glue gun
Step 2: Unscrew
Unscrew the halves of the maverick and take out the barrel. Unscrew the slide first, then the rest of the gun. Then, after taking the barrel out, reclose the gun without the barrel.
P.S. if you want the gun to have recoil, take both halves of the slide off of the little spring inside. Then, when priming the gun, make sure the slide stays BACK. Then fire. For silent mode, make sure the slide stays forward, then fire, same as always. Seperate 'ible coming soon!
Step 3: Saw
Take your hacksaw and cut off the arms of the gun. You will not need them.
Step 4:
Next, remove the rod from inside the barrel. This will thake some prowess. You dont need this, either. Then unscrew the barrel and separate the pieces. Take out ar's (air restrictors) which are the three pronged pieces; you dont need them. You dont need the big black or grey pieces, either. Put the remaining pieces back together.
Step 5: Glue
Hot glue the remaining pieces of the barrel together.
Step 6: Attach
Hot glue inside the inner octagon and attach to the octagon (or pentagon or whatever) on the maverick.
Step 7: More Glue
Drizzle glue on the outside of the spinner. Make sure none sticks to the barrel.
Step 8: Youre Done!
The gun should look like this. Load and fire! If you have any questions ask them in the comments. Please favorite and follow!!! Enjoy!!!
