Introduction: Nerf Titan Sniper Mod
This shows everything about this mod that I did.
I painted it battle radioactive
Ranges: 130-150 feet 30 degree angle
100-120 feet flat held @ 3 feet above ground
Internal mods:
venetian blind-type AR's taken out
sealed all air hoses
sealed pressure release valve
External mods:
custom stock
custom handle area
custom bipod
barrel/ missile attachment.
PLEASE NOTE
I also made a homemade silencer that has holes drilled in half inch CPVC in a spiral pattern. It is only compatible with streamlines because the barrel is somewhat long and the air would escape through the bottom holes.
Step 1: The Custom Bipod
I took the rails of an old broken longshot and glued them onto the bottom.
Step 2: The More Preferable Handle
I took off that ugly thing that holds the hornet in place.
Step 3: The Stock
I sawed off the other ugly thing on top that helps you pump when its on the ground.
Step 4: The Scope
I basically took off the other side of some cheap 2x toy binoculars and drew a little dot w/ marker.
Step 5: The Barrel
I have never seen this done before. I took a longshot barrel, sanded off the grooves at the bottom that are inside of it so I could detach it and make it more portable. I also took out the AR on the missile attachment so the barrel would nest inside of it for cosmetics and support.
Step 6: The Missile Attachment
Remember how I said I could take the barrel off? Well, I can also fit the missile on there now.
Step 7: Summary
all parts and components except silencer
