Introduction: Nerf Gun Pistol Mod
So This is a nerf gun witch I have modded to shoot 9 times as far!!!You all probably know this mod but I was bored so I made an ible on it!!!
This isn't really an amazing mod as everyone probably knows it.
What you will need:
A stretchy elastic band or two.
A nerf gun pistol with a pull back
What you will need:
Step 1: The Elastic Band
So for this mod you will need an elastic band. You can just use a regular postman band or you could use a thick one like me. If your band aren't long enough then you will need to tie them together.
1-Place the two bands so that they are overlapping each other.
2-Pull the end of the band on the top under the edge of the band on the bottom.
3-pull the end that you have put under the other band back up through the loop and pull tight.
If you don't understand then look at the pictures.
Step 2: Done!!!
now all that you have to do is loop it around the bottom of the barrel and around the draw back then you are done!!!
#>>>>WARNING <<<<#
If you put to many bands on the drawback can snap!!!
#>>>>WARNING <<<<#
