Introduction: Nest Box
Viele nützliche Insekten wie Wildbienen, Marienkäfer, Ohrwürmer usw. finden immer weniger Plätze zum Nisten und Überwintern. Dieses vorteilhafte Hotel ist ein wertvoller Beitrag zum Schutz von Arten und Umwelt und übrigens eine ideale Gelegenheit, die Kleintiere aus der Nähe zu beobachten. Je nach Insektentyp eignen sich folgende zur individuellen Füllung: Ziegel, Holzwolle, Moos, Stroh, Schilf, Bambus, perforierter Ton, gebohrte Holzstücke, Zapfen usw.
Materialliste:
2 Fichten-Dreischichtplatten 300x85x13 mm 4 Fichten-Dreischichtplatten 200x85x13mm 1 Fichten-Dreischichtplatte 200x125x13mm 1 Kiefernsperrholzplatte 300x 228x 4mm 1 Tarboard 310x 160mm 12 Teerpapiernägel 15mm 25 Wagner-Stifte 30mm 14 Wagner-Stifte 20mm 2 Ringschra 5: 12mm 500mmWenn Sie
Step 1: Marking and Drilling
Place the two sides mirror-inverted next to each other and mark the nails. Pre-drill them with a 1. 5 mm drill bit and hammer the nails (30 mm) in such a way that they are approx. 1 mm protruding.
Step 2: Continue Drilling
Nail the four boards together according to the picture. Since the beneficial hotel is to be set up outdoors later on, I strongly recommend the use of screws instead of glue.
Step 3: Now the Housing
Now assemble the housing, consisting of the previously used parts with the nails (30mm). Draw the nails on the plywood back wall and attach them with nails (20mm) to the back of the case.
Step 4: The Roof
Drill and propose four nails (30mm) according to the drawing in the roof board (280x125x13mm). Drill the support points of the roof board onto the housing.
Step 5: The Tarboard
Bend the papers on the edges of the roof and fix them with tea paper nails on the end faces of the roofing board. As an alternative, the tarboard can also be glued with contact adhesive.
Step 6: The Suspension Device
The suspension device is made of two ring screws and the enclosed aluminium wire. Drill two holes in the back wall and turn in the ring screws. Form a wire loop and attach the ends to the two ring screws. Of course, the Nützlingshotel can also be screwed directly to a wall, a garden fence or wooden peg through the back wall.
