Introduction: Nesting Bandsaw Vessels
These bandsaw vessels are inspired the irregular shapes of hand formed ceramic pots - like pinch pots. After making one, it was obvious that several more smaller ones could be made with the remaining material creating a set that nest together.
Materials
Wood 3.5 in x 3.5 in x 2 in (any size will do, as long as its within the capacity of your bandsaw, here I glued up two pieces of Cherry)
Wood 3.5 in x 12 in x .125 in (this is for the bottoms, this will determine how much each vessel sticks up when stacked, here I used Walnut)
Wood Glue
Finish of Choice
Tools
Bandsaw
- I used .125 in wide blade with 14 TPI
Spindle Sander (nice to have, but not required)
Clamps
Step 1: Cut Out Each Vessel
Sketch out an organic shape for the first vessel. Stay about 1/4 inch away from the edge.
Tilt the bandsaw table to 5 degrees. This will give the vessel a slight taper so that it is wider at the top than the bottom.
Begin on the left side of your outline and cut to you line, and then all the way around.
Draw what will be the inside of you vessel. This should be inset between 1/8 and 1/4 of an inch.
Tilt the blade to 6 degree before cutting. This will make the walls of the vessel thinner at the lip than at the base.
Repeat and continue this process creating smaller and smaller vessels. Each cut, angle the bandsaw table an additional 1 degree.
- The outside of the largest vessel is cut at 5 degrees. The inside is cut at 6 degrees.
- The outside of the second vessel is cut at 7 degrees. The inside is cut at 8 degrees.
- The outside of the third vessel is cut at 9 degrees. The inside is cut at 10 degrees.
Changing the angle, and therefore the taper for each vessel isn't necessary. All could be cut at the same angle, or even at 90 degrees.
Step 2: Glue Sides Closed
Glue the sides of each vessel closed with wood glue.
Clamp tight with camps, rubber bands or tape and allow to dry.
Sand the inside of each vessel smooth. A spindle sander makes this step go quicker, but this can be done by hand.
Sand up to 220 grit.
Step 3: Glue Bottoms On
Rough cut oversized bottoms for each vessel.
I chose a contrasting wood (Walnut).
Glue each bottom on. I used scrap wood to span across the top of each vessel.
Step 4: Final Details
With the bandsaw table tilted to the appropriate angle, trim up the bottom of each vessel getting as close as you can to the sides.
Sand the bottoms flush with the sides, and sand the outsides. I found using a sanding block with a round edge helped match the contours of each vessel. Sand up to 220.
I finished these with pure Tung Oil. It is easy to apply, and is food safe. Any finish would be suitable.
