Introduction: Nesting Material Holder - Bird
Nesting Material Holder - For Birds
Enjoying all the birds around our woods is spectacular; we enjoy all their wonderment.
I thought that by making nesting material available it would be nice.
Using colorful items would allow us to see the nesting work development.
Therefore, I came up with a way to have nesting material available for them to use.
A roof was added because, there was a concerned that the material would get wet and unsuitable for usage.
Using a metal wire cage - I believe it is used for sued feeding cakes to birds - is
already proven that the birds can attached to it and access the material.
Leaving strands out will allow birds easily see it and to pull it out.
I am using an old swing chair stand to hang from but it can be hung from a tree.
There is a hinge on one side of the cage that allows the managing and adding material.
I choose yarn and cotton balls; depending on the usage, I will add more or change to something different.
- Nesting material
- Yarn acrylic -
- color optional - I choose orange
- Size optional - I choose 5 inch lengths
- Cotton Balls - 100% pure cotton
- I used Jumbo size
- Building material
- Aluminum - Trim coil used for house siding (thickness - nominal 0.022 or 0.024 inch)
- Cut to size 12 inch by 12 inch
- Main bolt
- Threaded screw 1/8 inch diameter by 2 inches in length
- Nuts
- Thread nuts matching main bolt (5X)
- Washer large
- 1 inch diameter 1/16 thick 3/16 diameter center hole 2X
- Small washer
- 3/8 inch diameter 1/16 thick 3/16 diameter center hole 5X
- Metal wire cage - I believe it is used for sued feeding cakes to birds.
Step 1: Tools
Tools
- Scissors
- Razor knife
- Ruler and yard stick
- Micrometer
- Tape measure
- Pencil
- Deburring tool
- Drawing triangle
- 1/8 diameter drill bit
- Electric Drill
- Adjustable wrenches 2X
- Pliers - optional to bend the chain
Step 2: Roof Cutting, Deburring, Drilling and Bend a Pitch
Roof cutting, deburring, drilling and bend a pitch
- Roof
- cutting and deburring
- Using the razor knife cut the:
- Using the deburring tool
- go over all top edges
- go over all bottom edges
- Find center of 12 by 12 aluminum by:
- using the yard stick draw lines from one comer to the next to mark an X in the middle
- Drilling
- Drill 1/8 diameter hole in the center of the roof
- bend a pitch in the roof
- measure 6 inches from one edge
- mark a line from that mark thru the center hole
- Bend the roofing material in the center to form a slight angle. (this acts as a way for the rain to run off)
Step 3: Assemble the Cage to Bolt and the Roof
Assemble the Cage to Bolt and the Roof (reference attached concept drawing)
- Bolt to cage (MAKE SURE DOOR ON CAGE WILL SWING FREELY
- Main bolt
- Small washer
- Washer large
- CAGE
- Washer large
- Nut
- Tighten to pinch cage between the washers
- Cage assembly to roof
- Nut threaded onto bolt
- Small washer
- Push bolt thru roof (so that the V is facing down)
- Small washer
- Nut
- small washer
- Chain
- bend one link so at an angle so it will hang straight down
- add chain above last washer
- Small washer
- Nut
- Tighten nuts together to pinch chain between washers
Step 4: Cut Yarn and Grab an a Handful of Cotton Balls
There are several things to choose for nesting material
- Nesting material
- Yarn acrylic -
- I used Jumbo size
I just mixed the cotton balls with the cut yarn and filled the cage
The photos show some experiments on how much I wanted to use.
I pulled out some yarn ends to entice the birds
BUT -I believe you can over pack or under pack the cage the material will be easily for the birds to pull out.
Step 5: Thank You for Viewing My Instructable
Thank you for viewing my Nesting Material Holder - Bird
This is has been a great build for me with great outcomes
Using a metal wire cage - I believe it is used for sued feeding cakes to birds - is already proven that the birds can attached to it and access the material.
