Introduction: Newspaper Wall Hanging
Well in this a quite simple DIY a little tiring but simple and elegant and looks really beautiful.
Step 1: Step 1: Gathering the Material Needed
All you are going to need is some basic material:
1) Newspaper
2) Glue
3) Paints
Step 2: Step 2: Making the Stick
tear the newspaper in rectangular shapes. not much big near to a4 size sheet .there is no need of clean cutting.
now roll the paper with the help of a stick or with your hands only.
at the end of the roll put some glue and stick it.
Step 3: Step 3: Rolling Into a Circle
Now roll the stick to form a tight coil.
Now at the end of the coil put some glue and insert this end into another stick to make it longer.
This will enable us to make larger circles.
Now push some coil from the centre to give it a pyramid look.Seal the shape by applying some glue
now for this project, you will need to make:
1 circle of 5.5cm radius
1 circle of 4.5cm "
1 circles of 4cm"
1 circle of 3cm "
5 circles od 2cm"
12 circles of 1.5 cm
6 circles of 1cm"
Step 4: Step 4: Finishing
Now paint them as you want and either you can place them in the order I did or as you want.You can also put other decoratives item as well.
