Introduction: Nicole's Custom Oak Cage
Use these instructions to assemble the cage after the cabinet has been put together.. You will build the cage right on the cabinet. Each panel has been labeled with a letter on the top of the panel. Panels A and B are the back panels, C and D are the sides, E and F are the fronts with the doors.
Step 1: Panel a - First Half of the Back of the Cage
Put the cage bottom in place on top of the cabinet. The front edge is marked on the bottom of this piece. Now you will pull the back edge of the cage bottom over the back edge of the cabinet in order to put the screws in the predrilled holes through the bottom into Panel A. Line up the screw into the hole in the bottom of the panel and attach tight.
Step 2: Panel B - 2nd Half of the Back
Line this panel up next to Panel A and attach to the bottom with the 2 inch screws. Then use 2 inch screws in the sides of these two panels that touch each other and attach through the predrilled holes.
Step 3: Panel C - Right Side of the Cage (looking From the Front)
Now you will center the bottom back on the cabinet before pulling it to the side to attach panel C. Line up panel C as shown and attach to the bottom with three 2 inch screws. Then attach to Panel B with a couple 2 inch screws in the predrilled holes in the side of panel C.
Step 4: Panel D - Left Side of Cage
Pull the bottom back across center to expose the left side. Attach just like Panel C. Three 2 inch screws from the bottom and two 2 inch screws into Panel A.
Step 5: Divider Panel Bottom Support
There are two screws that hold this support to the bottom. In the back use the grey deck screw. Line up the hole from the bottom into the back hole of the support and tighten. Then expose the front of the bottom to install the long lag bolt that will go all the way through the divider support and into the bottom of the door panels. So for now, just run the bolt into the support but not sticking through.
Step 6: Slide Out Drawers and Door Panels E and F
Put the drawers into place on both sides of the divider support along with the screen covers on top of each. Now door panel E is the left side. To attach it, you will be using 2 inch screws in the predrilled holes in panel D. Make sure the top of panel E lines up with the top of panel D. It will also sit on the divider support. Then, do the same for the other door panel F. After both panels are attached, you will use two inch screws to attach to each other. There are predrilled holes for both frames. Then finish with The lag bolt through the divider support into the door panels. Now you can center the bottom onto the cabinet.
Step 7: Top Divider Support - Attach to Top
The support is labeled which end faces the front. Line up the predrilled holes in the top and use shorter screws to attach and tighten.
Step 8: Attach Top
The top simply lays on the top of the cage and use 1 5/8 inch screws to attach to the panels in the predrilled holes.
The top should be marked which edge is towards the front.
Step 9: Crown Moulding
The crown moulding just slips over the top and uses 1 1/4" screws in the blocks to attach to the top.
Step 10: Finished Cage and Divider
The divider panel is installed by opening the right side door, then put the bottom of the panel over the divider bottom support. Then tilt the top of the divider into the top support and turn the plastic knobs over the panel to hold it into place. That's it!
5 Comments
Question 2 years ago
Hi I have a large aviary that I bought 2nd hand very well built but it was plexiglass enclosed panels. Which I didn't care for (ventilation, climbing surface needed, also the injury factor). I would much rather have grate as in this one you have done. I have a caique.
I'm having a hard time finding what I want or either I don't know what its techncally called maybe? Where I can get it.
Here's what I have in photos.
Thanks for any advice
7 years ago
hello, I had a question. So i noticed that you had used a mesh one this particular build and i was wondering what it is. I have a parakeet and i was wondering if i would be able to get some of the mesh for him. The cage i have now is fairly small and he has issues flying about so i don't feel comfortable leaving his cage open while im gone. I know that i can't us stainless steel for his cage because i uses the bars to climb so that is why im asking.
Reply 7 years ago
This screen was custom ordered by the customer from a company in California, but there are quite a few places where you can order small amounts of screen. This was very heavy wire (10 gauge) and was fairly expensive. I usually get 16 gauge screen with the largest spacing being 1/2" x 1 1/2" openings between bars. You can check twinc.com for all of their wire mesh products.
7 years ago on Introduction
I have something similar that I started making over
10 years ago specifically for an indoor aviary, and now it's joined me
here on my 'new' property where I have carte blanche in my new home
where I now live alone because my wife hates me. At least I have my dog
and soon my birds to keep me company.
Bob from Down Under
That looks really good. I made something very similar for my zebra finches.
