Introduction: Nightstand CTE Project
3x 1X12 Common Board
1x ⅛ 2x4 hardboard
1x 1x10-6ft Common Board
Box of Deck screws
Box of finishing nails
Metal cabinet handle
Wood Varnish
Step 1: Planning the Project
I first made a couple drawings to get an idea of what I would do. But to fully realize my project I made a SketchUp draft to measure, proportion and in general get a much better view of my finished nightstand
Step 2: Cutting and Assembling the Drawer
I started with the drawer because it was the easiest to cut, sand, and build. I measured it 14x11x6" and attached it long plates to the side and short on the front and back. After that I drilled the bottom plate from flat wood in my yard. I then set it aside to varnish later, a handle was also ordered and put on later.
Step 3: Cutting and Sanding the Frame
The frame took the most time, not to cut but to sand. I measured one side 2ft tall and another shortened by the length of the shelf. After cutting them I sanded by hand from 60-150 grit. I fastened the sandpaper onto a wood block and used that to better sand my pieces, switching papers when I needed.
Step 4: Assembling the Frame
Step 5: Adding the Shelf
The wood I used for the shelf was thinner width wise than the top board, this was unintentional but, in the end, gave the finished project depth which was a fine addition. I glued support pegs below the second shelf so it could withstand more weight and be more sturdy.
Step 6: Varnishing the Drawer
Step 7: Varnishing the Frame
Using the same process made in the last step. I varnished the rest of the nightstand. This took a while to do because I had to brush 4 layers on to get a nice even coating on par with the drawer.
Step 8: Cutting and Nailing the Backboard
I cut out two pieces of hardboard for the backboard, one that will cover the drawer and the other the rest of the nightstand to the floor. I then nailed them in with finishing nails, some excess was found on some sides which I promptly filed off leaving a nice flat finish.
Step 9: Finished!
All done, the project is finished!
