Nikon D90 MC-DC2 Remote Shutter Hack
Intro: Nikon D90 MC-DC2 Remote Shutter Hack
ever need to control your shutter on your nikon but cant find that strange "accessory" plug?
need more distance on your remote
want to make a highspeed photography rig or have one that does not work for your nikon?
well me to so i have made this simple hack for you :)
STEP 1: Gather the Parts
go to radioshack or your parts bin and get
ONE In-Line 1/8" Phone Jack (3 PIN Stereo type)
ONE (or 2 if your making ur own shutter cable) 1/8" stereo Phone Plug
(these come in packs of 2)
one nikon MC-DC2 (works with MC-DC1 if your camera only supports that and probably other shutter releases)
STEP 2: Cut and Splice
cut your cord wherever you see fit and strip away the coating
peel back the metal shield and twist it off to the side
green- Focus (Ring)
white- Shutter (Tip)
red- NOT USED (X)
black / metal shield Ground (Sleeve)
we will use the canon standard pinout because its easy and you can use your canon gear on it
green- Focus (Ring)
red- NOT USED (X)
STEP 3: Solder and Test
put the wires on solder and test
REMEMBER TO PUT THE EARPHONE JACK HOUSING IN FIRST!
solder like this
Sleeve - Black wire + metal ground housing
Ring - Green wire
Tip - White wire
solder both the jack and the plug ... the jack should be on the MC-DC2 plug side and the plug should be on the remote side to make it easy
plug them together plug it in your camera cut it on hit the button half way it should focus hit it all the way it should capture the shot
solder like this
Ring - Green wire
Tip - White wire
STEP 4: Taking It to the Next Level (OPTIONAL AND NOT REQUIRED)
so you want to take it to the next level? adding a micro-controller or logic or analog circuit?
here is a simple way to do so
it uses 2 2n2222 NPN transistors and 4 10k resistors
you can use 5-12vDC to switch the transistors and if you use a 1k resistor at resistor 4 and resistor 3 to power it off 1.5-3.3v
IMPORTENT NOTE! THE FOCUS BUTTON MUST BE ACTIVE WHEN SHUTTER IS TRIGGERED
22 Comments
wiz9 2 years ago
In case you're still around and still interested, the Nikon proprietary connector pinout is up on pinout guide (one of the world's most useful sites).
https://pinoutguide.com/DigitalCameras/nikon_d90_p...
It's been a long time since I heard anyone say 1/8 inch plug. These days (and by "these days" I mean here in 2022 and back in 2010 when you published this) the plugs come in 2.5mm, 3.5mm, and 1/4 inch. Canon uses a 2.5mm. Hope this helps.
Jls62 3 years ago
wiz9 2 years ago
DennisM1 5 years ago
Jclarke775 5 years ago
AJB-nikon 8 years ago
December 1015 -- a new MC-DC2 has three wires, red, white, black. Black = GND, Wht = Focus, Red = shutter. I drove it from a PLC through a relay output module as follows: focus on, delay .25 second, shutter on, delay .25 second (i.e. .5 total), focus and shutter off. Seems to work fine.
ChrisG382 7 years ago
Hi, I just saw your comment, what is the relay you used for the controller? I'm having trouble using transistors...
bertus52x11 8 years ago
Thanks for the great I'ble! I'm fairly new to electronics and I would like to use the remote with an Arduino.
I'm not sure I understand your sketch correctly (Step 4). Where it states "Shutter 5-12V" or "Focus 5-12V": this is the digital pin of Arduino ("HIGH"). Then in addition to this I would need the transistors and the 10K resistances?
brian.t.wheeler 9 years ago
This worked great on my D3100. Now I can switch between the regular button and an Arduino controlled trigger. Thanks!
jonathanlurie 10 years ago
Thanks very much for this last (but actually not least) step! Just tried it for doing a Nikon D5100 remote with Arduino, and it works great!
In case other people would like to do the same (with arduino), remember to:
- trigger the focus first (as said above) (and leave it HIGH)
- let some time (half sec) for focusing
- trigger the shutter and leave it HIGH for the duration your photo needs
- nb: if you use the BULB mode (what i think is better to controle the speed..), remember that a shutter speed lower than (approx) half second won't work ('cause bulb is made for long exposures...)
Have fun!
Geeks with lasers 9 years ago
my camera doesnt have bulb mode (d3100) just shutter priority (up to 30 sec). If I want to use the shutter speed set on the camera, do i still have to leave the shutter pin high for the duration?
thanks
jonathanlurie 9 years ago
Ok, thanks. Guess i'm just going to have to try it and see lol
MadCreator 10 years ago
Hey, I want to make a shutter release controller with the transistor circuit but I am wondering if it isn't dangerous for the camera. Like the voltage are 3.3v on mine, and don't we need to put opto isolator for security of our camera ??
Thanks
MadCreator
jjiménez20 11 years ago
http://downloads.celestron.com/Archives/Telescopes/NexStar_SE/4-5SEcamera_shutter_cable.pdf
However, it only has ground and shutter release, not focus. How could I get this to work with the D3200 Nikon?
rcole-2 12 years ago
rjbatc 12 years ago
Sidney Floyd 12 years ago
skaramicke 12 years ago
Isn't it supposed to focus when I do that?
Or is the MC-DC2 sending power through too?
NeilJB 12 years ago
