Introduction: Nimbus 1800 VTOL Project
VTOL or Vertical Takeoff or Landing aircraft is one of the best design of combining between copter and airplane.
it mean combining the flexibility of the copter and durability of the plane, VTOL drone can be the best solution for autonomous drone that's can reach further distance and longer flight time.
Using Nimbus 1800 plane and convert it to VTOL is the easy es way to have VTOL drone. why...?
- Flight time approx 1 hour (using 25C 16000 Lipo) if u want more we can combine
6S 16000mAh Li-ion Battery for Fix wing mode and 6S 2200mAh Lipo Battery for VTOL mode
- Using Radio like Crossfire, the radio range up to 100km (depend on condition) full telemetry.
Take-off Weight: 4.8kg Suggested Payload: 800g Total Weight: 2.85kg(no battery)
Wingspan: 1800mm, Length: 1300mm Suggested
Max. Flying Height: 3500m Max. Flying Speed: 35m/s Average Speed: 15m/s to 16m/s
- Max Range 15km
Take off and land vertically
Step 1: Raw Materials
This is the basic raw material u need
- 1x MFD Nimbus 1800 Long Range RC FPV Plane Kit
- 3x 40A ESC xrotor for all motor front and rear
- 2x SunnySky X3520 720 kv Brushless Motor for front motor
- 1x DFDL 12inch 12x8 CW Wooden propeller for Front right prop
- 1x DFDL 12inch 12x8 CCW Wooden propeller for front left prop
- 1x SUNNYSKY X4112S 485KV Brushless Motor for rear motor
- 1x 1555 Carbon Fiber Tarot Propeller CW for rear prop
- 2x SHF12 12mm linear rail shaft support XYZ Table CNC Router 3D printer Part for front motor holder
- 2x 50cm 500mm 12mm * 10mm Carbon Fiber tube for front motor holder
- Some Nylon Hinge For RC Airplane 15 X 27 Mm
- 3x M6 locknut
- 2x double head motor servo RDS3115mg 15kg for front motor transition
- 1x 22.2V 16000mah 6S 22ah 25C Lipo XT60 25C
- Enough AWG16 silicon Red & Black, AWG14 silicon black & red, AWG 30 silicon Red & black
- 1x Landing Gear Homemade carbon 40 Class Up
- 2x Header 3pin SET Header+Terminal+Housing pitch 2.54mm 3 pin for servo connector
- Some 10x M3*8mm Black Aluminum Spacer M3x8mm, 50x M3x18 + M3x12 + M3x30 + M3x20 + M3 Locknut
- 1x Digital Airspeed Sensor Pixhawk PX4 Flight Controller i2c
- 1x Module ESC Power Distribution Board 5V & 12V BEC
- 1x Pixhawk PX4 Black PIX 2.4.8 + Buzz +SD 4gb + Safety Button
- 1x Remote Control Transmitter and Receiver 2.4GHz 16CH
and some 3D printed component
u can download here https://www.thingiverse.com/thing:3833139
Step 2: Front Motor Mount
- Replace the original motor mount with 12mm OD x 10mm ID Carbon Fiber tube and SHF12 12mm linear rail shaft
- Cut a pair carbon tube 6 inch long and put SHF12 on it
Step 3: Front Motor and Servo
Using spacer and motor bolt mount the SunnySky X3520 720kv Brushless Motor to the servos
Step 4: Wing Motor Placement
place the tube to the original mount and bolt it
PS: bolt it hard enough
Step 5: ESC Placement
U can place the Xrotor 40 amp ESC beneath the wing and organize the wire properly
PS: this include additional servo wire, using 3 pin header mount it at the edge of the wing
Step 6: Using Lock Nut
i prefer using lock nut than the original nut from the motor to reduce the risk of prop loose during flight
Step 7: Rear Motor Mount
using my 3D component u can mount the rear SUNNYSKY X4112S 485 KV Brushless Motor and organize the Xrotor 40 amp ESC on the tail section
Step 8: Landing Gear
usually this type of airplane is using for carrying big camera in the bottom, so u need a landing gear for it
Step 9: Pixhawk Schema
i use this configuration for my pixhawk 4
Step 10: Air Sensor Installation
this is important especially for autonomous flight, air sensor will get u an accurate air speen needed for lifting the air plane. so install it to the pitot right
Step 11: Pixhawk 4 Setup
PS: before u set all parameters please do this :
- Upgrade ths pixhawk to the latest stable version
- reset all to the default setting
- do all calibration including gyro, compass, GPS, motor calibration and radio calibration
- set the Q_ENABLE : 1 to activate the Quadruplane
Step 12: Test Your Motor Direction
- detach all the propeler
- Arm it and test the direction just like picture above
Step 13: Test Your Servo Transition
make sure when in plane mode all servo facing front and in quad mode facing up
PS: Test it on the ground
Step 14: Test All the Tail and Aileron
check all the direction of your aileron and tail is right :
- Roll to right -> left aileron down and right aileron up & both tail right
- Roll to left -> left aileron up and right aileron down & both tail left
- Pitch up -> both tail up
- Pitch down -> both tail down
Step 15: Autonomous Flight
from here, autonomous flight seems so easy, but there is a lot of procedure has been done before flight. just like full size plane, there is a lot routine , check list and others.
Good luck and have a good flight... Remember, fail is a part of the lesson...:)
