Introduction: Ninja Throwing Star Christmas Tree Ornament
This year we have puppies who will eat any fragile ornaments we put on our Christmas tree. It's really plain though, and is in desperate need of some sort of decoration. Well these ornaments are pretty cool, and are safe if the little munchkins (puppies) get a hold of them.
Step 1: This Is What You Need:
Grey fleece or felt
Ribbon
Needle and thread or sewing machine (I'm too impatient to use a needle and thread :P) You'd probably be better off using grey thread.
Fiber fill or some random bits of material and yarn since you used up all your fiber fill making an xkcd pillow. This is optional, however.
Scissors
A ninja star printed off of the Internet. I went with a four pointed one for this, since it was very simple.
Ribbon
Scissors
Step 2: Chop Chop
Print your ninja star and cut it out, including the circle in the middle and then pin it on the grey fleece or felt that you're using so it won't move while you're trying to cut it out. My first one was printed on a piece of paper that was 7" by 5", and the second one was on a piece that was 8" by 10". The one that was printed on an 8" by 10" piece of paper was much MUCH easier to sew and cut out. Plus, it didn't look as weird in the end.
For this I'm not even going to deal with having to turn it inside out and stuff, since that would just be kind of a pain in the butt. So it really doesn't matter about the right sides out or anything like that.
So cut out two ninja star shapes.
You may want to draw the circle you're supposed to cut out onto the material, since it's kinda hard to cut out a good circle when you're trying not to cut up the paper.
Step 3: Well Well Well...
Sew the two cut out ninja stars together in the middle first. Be sure to line them up though, or that will be one wonky ninja star.
Once you finish sewing the inside together, you must sew the outside together too. Unless of course you don't want to. But whatever, anyway sew along the outside (and try to sew as close to the edges as you can) until you get to where you want the loop for hanging on the tree to be. Make a loop with the ribbon and put the two ends of it in the star and just sew over them.
Don't worry if the sewing is a bit... off if you're using a sewing machine, it'll definitely take time to get used to making these. Try to sew in straight lines though! If you go off the material a little bit don't try to fix it until you've sewn the rest of it or it might turn out weird.
For the part you will put the stuffing in, I suggest you use a side instead of a point, since that will make it much easier to put the stuff in and keep it in while you're sewing it completely shut. You really won't need much to stuff it with, especially if you save your scraps of fleece you cut out. If you wanted to you wouldn't even really have to put anything in it at all. In fact, I think they look better without anything in them.
After you stuff it (or don't stuff it) sew up where you put the stuffing in. Then you could cut off the excess pieces of material around the edges if you don't like the look of it.
Step 4: Hang It on the Tree!
Yay! Once you're finished you can hang it on the tree and then make more for the ninja army that will... Uh never mind, you're not supposed to know about that.
If you want to give these as gifts you could embroider someone's name on it, and the year or whatever you want. But you might want to do that before you sew them up.
