Introduction: Nitro Fuel Bottle,
This is Super Easy to Create a Fuel Filler for Nitro RC Cars!
I decided to create one, since I got my RC Without Fuel Bottle, and I was struggling to get the Big 5.0 L Tank to fill my car! And was too lazy to buy one.
This is Super Useful For someone who doesn't have a fuel Bottle! And I really recommend making one!
Super easy to move Fuel to tank! Or Back to tank! Takes only a Squeeze!
You Require
- Something Sharp to make a hole for straw,
- A Plastic Straw, that has the bendable end!
- Hot Glue Gun.
- Bottle, Something that is squishable I'd recommend 1 Liter.
If you want Long Lasting Bottle,
I'd recommend Silicone Glue or something to seal the straw from Leakage by cap.
Optional
- 3D Printer
Step 1: Creating Hole Ontop Cap
Drill or melt, Just make sure the straw fits, Not too tight, nor too loose.
I personally used my screwdriver. to make a hole, Easy!
Step 2: Straw in the Hole, Then Hot Glue!
Cut the Straw to length you require.
Fit your straw into the hole!
  • Optional! Use silicone to seal around the straw instead of using hot glue gun!
If No Silicone sealant
Use glue gun. Try to glue the whole cap, to minimize leakage!
Step 3: Optional, Fuel Nozzle Cap
Optional, Printing
3D Printing Fuel Nozzle stopper for straw,
Make sure to measure your straw Size, 3D model i created Requires bit Size tweak to fit your straw.
File OBJ link for print
https://www.thingiverse.com/thing:6530993
Should take under 5 min to print depending of Straw size
Step 4: Enjoy! Using It!
Id personally test the Fuel bottle with water, See if it leaks or Has a problem.
If you did everything correct you should work perfectly! Enjoy your new Fuel Bottle
