Introduction: Nixie Watch Prototope_a V5. Full Datasheet
Hello.
This is full source code + datasheet + all what you need to build your own nixie watch.
This is new revision of model prototype_a. Now it is archiewed version.
This watch was build for my friend. Casing - brass, bracelett -leather.
If someone need inspiration or small worklog - write in coments, or check my instagram/FaceBook page.
Previous prototype_a alpha on instructables that use Transformer as power source https://www.instructables.com/id/Nixie-Watch-Proto... on this project source was lost due hdd milfunction
Build your own Steampunk Nixie watch
Note that wach work on hight voltage!!!
Note that youll need some junk from ebay!!!
Step 1: Characteristics
Rechargeable battery via micro-USB.
Description: This is Fully Assembled and Tested Nixie Watch with 4 Pieces IN-16 NOS Tubes + 1 Tube blink. Power By: DC 5V via rechargeable battery or via USB cord. Time before recharging: 12-16 hours in active mode or more than month in passive mode User Selectable: 24HH-MM-SS/ DD-MM-YY / Energy level/ Change on - off Dimension: Width 76mm x Height 50mm x Depth 26mm
(+- this depend of your casing. 3d printed or not\design etc)
Handmade!
Little video https://instagram.com/p/08F--GMSeH/?taken-by=prot...
On next Step datasheet
Step 2: Parts and Datasheet
Datasheet attached on top
Parts:
- Capacitor 10 uF 4 pcx
- Capacitor 100 nF 5 pcx
- Capacitor 100 nF 3 pcx
- Capacitor 1 nF 1 pcx
- Zener diode 3V6 1 pcx
- Diode ES1J 1 pcx
- MicroUsb 1 pcx
- inductor SCB0704-331М 330 uH 1 pcx
- Transistor ZVN4525E6TA 1 pcx
- Transisror MMBTA92 4 pcx
- Transistor MMBTA42\PMBF107 16 pcx
- Transistor BC847BS 1 pcx
- Supervisor TLV431AIDBVR 1 pcx
- RTC DS3231SN 1 pcx
- Li-pol charging element TP4056 1 pcx
- Buttons TM1103R25B-2500-TR 3 pcx
- Atmega16a-AU 1 pcx
- Nixie tube IN-16 4 pcx
- Nixie tube IN-3 1 pcx
- Resistor 100 k 6 pcx
- Resistor 100 k 15 pcx
- Resistor 10 k 25 pcx
- Resistor 4.7 k 1 pcx
- Resistor 2.2 k 3 pcx
- Resistor 2.2 k 1 pcx
- Resistor 1 M 4 pcx
- Resistor 22 Ohm 1 pcx
- Resistor 30 k 2 pcx
- Thermoresistor NTC 10 k 1 pcx
- Contacts PLLD1,27-80 1 pcx
- Connectors PBD1,27-08S 4 pcx
- Li-pol battery 643456M15 3.7V 1200mAh +PCB 1pcx
Step 3: PCB
Step 4: Software
On archieve software
