No Cost Crampons
Intro: No Cost Crampons
Crampons are a must have if you plan to brave the elements! The traction crampons provide is absolutely paramount to safety when traversing on ice. Crampons start at around $65.00 and usually consist of rubber and chains. In this tutorial, I will show you how to rig up some of your own at almost no cost from some leftover workbench materials. These crampons will be custom fit to any shoe and can be removable or permanent.
You will need:
- 10 7" zip ties (+4 if you want them permanently fixed on shoes)
- 17 1/4 nuts (-4 if you want them permanently fixed on shoes)
- Scissors
*Optional*
- Safety Pin (to unlock zip ties)
STEP 1: Start at the Heel
1. Start by creating a simple "L" with 2 nuts on the horizontal zip tie. (picture 1)
2. Thread the zip ties through the nuts. Make sure the heads of the zip ties are flush against the horizontal "L" zip tie (Red Circles).
Picture 2
1. Add 2 nuts to the descending zip ties.
2. Add 2 more connecting both zip ties
STEP 2: Middle of Shoe
1. Attach 2 zip ties facing outward. (Red Circle).
2. Slip on 2 more nuts then combine the zip ties using 1 nut in the middle, then add 2 more.
Picture 2
1. Add 2 more zip ties at the bottom. (Blue Circle). This will wrap around to make the front strap.
STEP 3: Slip in Your Straps
1. Slip in 2 more zip ties on these nuts: (Purple Circles). This will be your middle strap.
2. Connect the "L" at the heel. This will be your heel strap. (Red Circle)
-Blue Circles are your toes strap-
***Note***
I cut the ends off my zip ties to make it easier to see. Do not do this until you have adjusted the front in the next step.
STEP 4: Top of Shoe (Removable Crampons)
Proceed to next step for Fixed crampons.
1. For removable crampons: add a nut to each zip tie and connect both with 1 nut.
2. Fold the zip ties back over and slip under each respective nut. Pull tight to tighten your crampons.
STEP 5: Fixed Crampons
1. Simply connect the 2 zip ties with a single nut. Lock them in place by adding 2 additional zip ties and clipping them at the head. (Red Circle)
STEP 6: Tighten and Finish
1. Once you have the top of your crampons tight, adjust the rest of your shoe starting at the heel.
2. After tightening everything up, clean up your crampon by cutting off all the loose ends.
Congratulations! You did it! You saved at least $65.00 by using some spare materials you found on your workbench. Brave the elements safely. Your mom will thank you.
16 Comments
masterbuilder 5 years ago
Suicid 6 years ago
Made such last winter. Nice idea, but unfortunately did not last long in the city env - fell apart in about half an hour walking the icy asphalt - ties simple got broken under the sole.
May be need some other sort of ties? Any recommendations?
SEKTHEBOSS 8 years ago
flippin' epic
SteveMann 8 years ago
Very nicely done and great to see how easy it is to remove and replace (reuse).
loptica62 8 years ago
Now, this is what I call pure genius,,,,,
graydog111 8 years ago
firefightermeyer, I forgot to tell you. This is a great instructable and is well planned and documented. Good job.
AndreasO1 8 years ago
The zip ties will break after a short time.
But shoelaces should work as an alternative to zip ties.
Maxxron 8 years ago
I have done something similar with paracord before that worked quite well. But this is one impressive instructable. I have loads of zip ties just waiting for a good purpose!
burnerjack01 8 years ago
I've heard that white ties will degrade from UV exposure but black ones are UV stabilized. Just sayin'.
firefightermeyer 8 years ago
Mine work great. I just hiked Zion National Park in UT, USA
roccitman 8 years ago
Love it! (not really crampons--I grew up mountaineering :) ) We call these stabilizers. Now you're ready for Summit For Life 2016!!
(Google it :) )
armedtodream 8 years ago
rb2001 8 years ago
Taking scouts ice fishing soon. Will be adding this to our get prepped meetings.
I would love to see pictures if you end up making a bunch. Thanks for your interest!
discostu956 8 years ago
Thanks!
