Introduction: No More Wet Room
Idea
I was thinking in some daily problems i have and onde of them is that i have always forgotten my window open and when starts to rain outside all of my stuff gets wet. So, I decided to use a rain sensor which closes my window when it gets wet. This is a part of the whole project because i couldn't manage time to construct the device which will actually closes the window, but to demonstrate the system i used the code and materials bellow to make one led turn on when the sensor activate.
Materials:
- Protoboard x1
http://produto.mercadolivre.com.br/MLB-716294209-p...
-Arduino UNO3 x1
http://www.institutodigital.com.br/pd-363bf9-ardui...
-Rain sensor x1
http://produto.mercadolivre.com.br/MLB-719086015-m...
- Jumpers x6
http://produto.mercadolivre.com.br/MLB-841642978-c...
-USB Cable x1
-LED X1
http://www.institutodigital.com.br/pd-154a7c-kit-2...
Code:
/* Flame Sensor analog example.
Code by Reichenstein7 (thejamerson.com)
For use with a Rain Sensor with an analog out!
To test view the output, point a serial monitor such as Putty at your Arduino.
- If the Sensor Board is completely soaked; "case 0" will be activated and " Flood " will be sent to the serial monitor. - If the Sensor Board has water droplets on it; "case 1" will be activated and " Rain Warning " will be sent to the serial monitor. - If the Sensor Board is dry; "case 2" will be activated and " Not Raining " will be sent to the serial monitor.
// lowest and highest sensor readings:
const int sensorMin = 0; // sensor minimum
const int sensorMax = 1024; // sensor maximum
int led = 4;
void setup() {
//initialize serial communication @ 9600 baud:
Serial.begin (9600);
pinMode (led, OUTPUT);
void loop() {
// read the sensor on analog A0:
int sensorReading = analogRead(A0);
// map the sensor range (four options):
// ex: 'long int map(long int, long int, long int, long int, long int)'
int range = map(sensorReading, sensorMin, sensorMax, 0, 4);
// range value:
switch (range) {
case 0: // Sensor gettin wet
Serial.println("Chuva");
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltade level)
delay(50);
digitalWrite(led, LOW); // turn the LED off by making the voltade LOW
delay()50;
break;
// wait for a second
case 1: // Sensor getting wet
Serial.println("Umido");
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(500); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
delay(500);
break;
case 2: // Sensor dry - To shut this up delete the " Serial.println("Not Raining"); " below.
Serial.println("Seco");
break;
delay(1); //delay between reads
6 years ago
This would be great where we used to live in Okinawa :) It rains often.
