Introduction: No Nails Harlequin Table
About: Hi everyone! I'm a hardcore DIY'er, I've published 11 DIY books, just produced my own TV show called Make Your Mark for PBS/APT, I make YouTube videos every week and I'm buried under a mountain of craft suppl…
Make a small side table with standard cut lumber and without one single nail!
Step 1: You'll Need
E-6000 glue
Americana Decor Chalky Finish Paint
Small hammer
Brass thumbtacks
Needle nose pliers
Paintbrush
Ruler
Sandpaper or sanding block
WOOD MEASUREMENTS:
(1) 1" x 12" x 18" - Table Top
(2) 1" x 2" x 14" - Table Skirt
(2) 1" x 2" x 9" - Table Skirt
(4) 1" x 1" x 24" - Legs
(2) 1" x 1" x 5 3/4" - Crossbar Support
(1) 1" x 1" x 12 1/4" - Crossbar Support
Step 2: Watch the Video Tutorial Here!
Step 3: Assemble
Evenly glue the two 1"x2"x14" and the two 1"x2"x9"
to the underside of the 1"x12x18" table top to create the skirt
*Let the glue set for about 15 minutes
Next, glue the 1"x1"x24" legs on the inside of each corner of the skirt
*Let everything dry for at least one hour
Step 4:
Glue the 1"x1"x5 3/4" pieces in between the legs about 8" up
*Let dry for 1 hour
Glue the 1"x1"x12 1/4" between the two 5 3/4" pieces
*Let everything dry for at least 2 hours
With a ruler, create your harlequin (diamond) pattern
Paint the diamonds with Americana Decor Chalky Finish Paint
Step 5: Paint and Embellish
Paint the legs and skirt of the table and let dry
Mark the edge of the table top every inch
Holding the thumbtacks with needle nose pliers, tap them into the edge of the table
Sand the edges with a sanding block or sand paper to expose the wood on the edges
