Introduction: No Touch Lid
During the COVID-19 Pandemic, germs everywhere, especially on trash cans. If you have to throw away a used tissue, you would need to lift the lid of the trash to throw a used tissue away. That is why I have created a "No Touch Lid" using my Arduino Starter Kit, to minimize the spread of germs.
Step 1: Making a Box
- Cut out 6 5x5 squares from the poster board with an exacto knife
- Hot glue 5 of the squares together, leave one of the squares aside and the top of the box opened
- For the top of the box, use duct tape to make a hinge for the lid on the box.
Step 2: Writing a Program
- Using Chat GBT, ask it to write a Program:
"Write a code using a sor4 ultrasonic detector and an uno microcontroller with a sg 90 servo motor, have it rotating at 90 degrees when an object is detected less than 5 inches when the object disappears the servo should rotate back to 0"
- Chat GBT should give you a program that you will need to copy and paste into your Arduino IDE (The code is very important, so you know how to do all the wiring.)
Step 3: Follow the Program
- Now you will need to grab your tools (Arduino Uno Controller Board, Breadboard Jumper Wires, Female-to-Male Dupont Wires, Tie-Points BreadBoard, USB Cable, Ultrasonic Sensor and Servo Motor SG90)
- Using the USB Cable, plug it into the Arduino Uno Controller Board and your Computer
Step 4: Wiring the Ultrasonic Sensor
- Grab the Ultrasonic Sensor and Female-to-Male Dupont Wires
- Take the yellow wire and connect it to the Ultrasonic Sensor in the "Trigger" slot
- Take the other end of the yellow wire, and plug it into the Control Board in pin 2
- Then, take the orange wire and plug it into the Sensor in the "Echo" slot
- Take the other end of the orange wire and plug it into the Control Board in pin 3
- Then take the red wire, and plug it into the ____ Slot
- Plug the other end into the Tie-Points Breadboard, on the red side
- Then Take the black wire, and plug it into the "GND" Slot
- Take the other end and plug it into the Tie-Points Breadboard, on the Blue side
Step 5: Wiring the SG90 Servo
- Grab the SG90 Servo and Breadboard Jumper Wires
- Take an orange wire, and connect it to the orange wire that is connected to the Servo
- Then take the other end of the wire into the Control Board in pin 9
- Take a red wire, and connect it to the red wire that is connected to the Servo
- Then take the other end of the wire and plug it not the Tie-Points Breadboard on the red side
- Take a black/brown wire and connect it to the black/brown wire that is connected to the Servo
- Then take the other end of the black/brown wire and plug it not the Tie-Points Breadboard on the blue side
Step 6: Wiring the GND and 5V
- Grab a red and white Breadboard Jumper Wires
- Take one end of the red wire, and plug it into the "GND" on the Control Board
- Then, take the other end of the red wire and plug it into the blue side of the Tie-Points Breadboard
- Take the white wire, and plug it into the "5V" on the Control Board
- Then, take the other end of the white wire and plug it into the red side of the Tie-Points Breadboard
Step 7: Finishing the Box
- Take your Box, Exacto Knife, Ultrasonic Sensor, and SG90 Servo
- Attach the Ultrasonic Sensor to the front of the box/the opening angled up a little bit
- Take the Exacto Knife, and cut a little opening for the Servo to fit in, on one side of the box
- Tape down the Servo into the slot you made to make sure it is secured
Step 8: Verify and Upload
- Copy and paste the program Chat gives into the Arduino IDE
- Once the program is in the IDE, click on the green check mark in the top left hand corner to verify the code
- After the code is verify, click on the green arrow in the top left hand corner to upload the program to the Arduino Uno
Step 9: Testing the No Touch Lid
- Lastly, test the final product
- Place your hand in front of the Sensor (The lid should go up and stays up)
- After the lid is up, then remove your hand from the Sensor, which will close the lid
- If it doesn't work, go back and follow the steps and program again to make sure you did it correctly!
