Introduction: No Solder Vibrobot
Starter robot. It is lots of fun on a hard surface. No soldering required and can be built in minutes.
Step 1: What's Needed:
Parts:
1 Tall sturdy cup.
1 Electric toothbrush. Mine was from the dollar store.
4 decent size paper clips
glue
1 Tall sturdy cup.
glue
Step 2: Glue It Up.
Remove brush part from toothbrush.
Glue four paperclips at 12, 3, 6 and 9 o clock so to speak on the inside edge of the cup so that part of the paperclip extends above the edge of the cup. you will want to make sure they are all the same length so the cup is level when you stand it on the paper clips.
Let the glue dry..
Glue in the electric toothbrush.
Let the glue dry.
Let the glue dry..
Let the glue dry.
Step 3: Time to Play.
Turn on the tooth brush and set it down on a hard surface. Watch it dance around. Cool!
Step 4: Update:
Alternative vibrobot.
Step 5: Vibrobot Upgrade Plan:
In the works:
If you wanted a two directional movement you could upgrade this set up with a wire wrap circuit using an astable 555 circuit.
