Introduction: NodeMCU With Blynk App/Server
What is Blynk and how it works, watch their campaign video !
First, As it turns you can program the NodeMCU with Arduino IDE check the video above.
Here is the Written Tutorial for the setup : https://www.teachmemicro.com/intro-nodemcu-arduino/
- Breadboard
- Two NodeMCUs 1.0
- Arduino Uno or any other type
- Jumpers
- USB Power Cables
Step 1: Here Is an Overview
1st - Download Blynk application
2nd- add your devices as shown in the video and copy the Authentication Token created for our device as we will use it later in the code
- In this project we are setting two NodeMCU devices and connecting them to oue WiFi network , then start to sending data (Integer/Character) from NodeMCU 1 to NodeMCU 2
- Also we will connect Arduino UNO to NodeMCU 2 through wired serial communication
- the data recieved from NodeMCU 1 will be sent to the Arduino UNO at the end and we can use this single to toggle a LED or any other thing
- we will display on the Blynk Application wether the LED is ON or OFF
Step 2: NodeMCU 1 Code
no wiring is needed for Node MCU 1 as it will connected to wifi and just send "1" or "0"
all we need is the Authentication Token we created
Built in LED in D2 is used as indication for successful WiFi Connection
then start writing the code above
Step 3: NodeMCU 2 + Arduino Codes
NodeMCU 2 - we used D7 as RX and D8 as TX , built in LED in D13 is used as an indication
Arduino - we used Pin 8 as RX and Pin 9 as TX
Wiring:
- D7 in NodeMCU to Pin 9 in Arduino
- D8 in NodeMCU to Pin 8 in Arduino
- VIN in NodeMCU to 5V in Arduino
- GND in NodeMCU to GND in Arduino (Common Ground)
After setting all connections , please start downloading the code above in the NodeMCU 2
Step 4: Arduino Code
Here is the code needed to recieve the data from NodeMCU 2 to Arduino
you can connect a LED to Pin 13
