Introduction: Nonlinear Letter Scale - 1g to Infinity
Nonlinear letter scale that can measure various weight.
- It has 1g resolution for light objects.
- It can measure relatively heavy objects as well. No overflow.
- Easy to assemble (it consists of 3 parts).
- Easy to calibrate.
- Stainless wire (thickness : around 1.5mm)
- Some weights to calibrate
Step 1: Print Parts
Print parts with your 3D printer.
- Print with supplied posture.
- Support is not necessary.
- "scale.stl" is for two-layer print technique. To give different color to the texts, use "pause at height" function of Cura Slicer to change the material during print.
- "scale-1layer.stl" is single layer version, all texts and indices are just holes.
Step 2: Assemble
Assemble the printed parts.
- Use soldering iron to weld the pin to the scale.
- Make sure that the index rotates smoothly. Do not set the pin too tight.
Step 3: Zero Caribration
Calibrate zero of the scale.
- Attach hook using stainless wire.
- Add some weight to adjust the zero.
- It is better to calibrate zero without main weight for the better sensitivity.
Step 4: Non-zero Calibration
Using an object of known weight, calibrate non-zero point.
- Adjust the amount of main weight so that the scale shows correct weight of the payload.
- Amount of main weight does not affect to the previously calibrated zero point.
- Calibration with a single object is sufficient. All other weight can be measured correctly.
Theory
- Angle of rotation of the scale is calculated by the arctangent of the weight of payload, so it can map from 0g to infinity into 0 - 90 degrees.
