Introduction: Notebook Heater
Step 1: Code
void setup() {
#include "U8glib.h"
int analogInput = 0;
int Percent ; //We want it as a whole number
float Voltageout = 0.0;
float Voltage = 0.0; //We want it with decimal places
float R1 = 97000.0; //resistance
float R2 = 10000.0; //resistance
int value = 0;
U8GLIB_SH1106_128X64 u8g(10, 9, 12, 11, 13); // pinout, see page
void draw(void)
 u8g.setFont(u8g_font_helvB14r); // font
 u8g.drawStr(19, 16, "BATTERY");
 u8g.setPrintPos(7,55);
 u8g.setFont(u8g_font_helvB18r);
 u8g.println(Percent);      //Prints Percent
 u8g.println("%");
 u8g.setPrintPos(63,55);
 u8g.setFont(u8g_font_helvB18r); //A slightly larger font
  u8g.println(Voltage);       //Prints the voltage
 u8g.println("V");
 u8g.drawRFrame(0, 23, 128, 1, 0);
void setup(){
  pinMode(analogInput, INPUT);
void loop(){
  value = analogRead(analogInput);
  Voltageout = (value * 5.0) / 1024.0;
  Voltage = Voltageout / (R2/(R1+R2));
  if (Voltage<1) {
  Voltage=0.0; // get rid of unwanted readings
  if (Voltage>5.00) { // if Reading are too large
  Voltage= Voltage/10;
  Percent = ((Voltage-3)/(4.2-3))*100; //votage divided by max cell votage times 100 = the cells current percentage
 u8g.firstPage();
 do
   draw();
 while( u8g.nextPage() );
delay(500);
}void loop() {
}#include <OneWire.h>
#include <DallasTemperature.h>
#include <avr/wdt.h>
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
int maxTemp=30;
int minTemp=26;
const int relayPin=9;
unsigned long interval=30*1000; //30sec recomended
unsigned long lastConnectionTime=0;
int Temp=25;
float tempPrev;
float temp=20;
void setup() {
 Serial.begin(9600);
 pinMode(relayPin,OUTPUT);
 wdt_enable(WDTO_8S);
 sensors.begin();
 setPwmFrequency(relayPin, 1024); //division on 1024 for ~30Hz
 pinMode(13, OUTPUT); //Blick LED
void loop() {
 if(millis() - lastConnectionTime > interval) {
  digitalWrite(13, HIGH);
  tempPrev=temp;
  sensors.requestTemperatures();
  temp=sensors.getTempCByIndex(1);
  digitalWrite(13, LOW);
  if (temp == -127) {temp=tempPrev;}
  int val = 255-255*(temp-minTemp)/(maxTemp-minTemp);
  if (val<0) {val=0;}
  if (val>204) {val=204;} //80% -this 230 or 450W; 204 for 400W
  analogWrite(relayPin, val);
  lastConnectionTime = millis();
  Serial.print("Temp=");
  Serial.print(temp);
  int valperc = map(val, 0, 255, 0, 100);
  Serial.print(" Power=");
  Serial.print(valperc);
  Serial.println("%");
 delay(1);
 wdt_reset();
void setPwmFrequency(int pin, int divisor) {
 byte mode;
 if(pin == 5 || pin == 6 || pin == 9 || pin == 10) {
  switch(divisor) {
   case 1: mode = 0x01; break;
   case 8: mode = 0x02; break;
   case 64: mode = 0x03; break;
   case 256: mode = 0x04; break;
   case 1024: mode = 0x05; break;
   default: return;
