Introduction: Nursery Mobile W/ Camera
If you liked the video please subscribe to our YouTube channel!
How do you remotely spy on your baby when you are worried about them in their crib without making the nursery look like a police state with cameras all over the room? Simple, build a wifi camera into the mobile.
You can also see the full blog post at: http://studiograyhouse.com/diy-nursery-camera-mobile/
SUPPLIES(affiliate):
FeltShape templates
1-5/8 inch piece of round basswood
Embroidery needles
Embroidery floss
Bag of low loft batting
Clear string
Cording
Indoor security camera
Step 1: Cut Felt & Batting
Start by cutting the shapes out of the felt and batting. Cut two matching shapes out of the felt, one for the front and one for the back. Cut the same shape out of the batting. Then trim 1/8" off the entire perimeter of the batting. The batting should be about 1/8" smaller than the felt when sandwiched between the two felt pieces.
Step 2: Sew the Shapes Together
Use an embroidery needle and embroidery floss to sew a blanket stitch around each object. We pushed the needle through the back piece of felt because we were sewing two pieces of felt together, the knot needed to go between the two pieces of felt.
Finally, we brought the needle back down through the loop we made. We repeated this process all the way around the object.
Step 3: String Objects
Connected the shapes together using clear string. Attach the top one shape to the bottom of the next shape and so on.
Step 4: Embed Camera
Use a router with a plunge mount and cutting bit to make the hole for the camera. The camera mount makes a great template.
Step 5: Hang Mobile
Finally, use a drill to make three holes in a triangle to attach the cord used to hang the mobile from above. Then, drill smaller holes for each clear string, connecting the objects together, to hang the objects from below.
That's it! We hope you like the project and to more projects like it visit Gray House Studio.
