Introduction: OBJECT FOLLOWING/AVOIDING ROBOT
Hi guys, we have made a project which is very compressive, easy to make and very good to watch, a very good project to start for college students and beginners. This robot brained with ARDUINO UNO, which is a microcontroller controlling the ultrasonic sensor and motors to move accordingly when the sensor senses any object between a distance of 10cm it follows and beyond that it will avoid. It is very nice to watch a robot following an object and going away in reality, so you people can follow the instructions make such simple good starting projects by yourself at home with our guidance and for further free video tutorial everyone is welcome to our youtube channel where you will get the whole video tutorial with basic guidelines to make such innovative creative projects. Guys one last thing don't be confused as our channel name has been changed from S_R Tronice to Voice Of Technology.
https://youtu.be/8WKsG0Buj-Y
Step 1: COMPONENTS:
Everyone will get the components from the links given also from their localities
BUY EXACT COMPONENTS AT LOW COST:-
1)arduino- http://amzn.to/2klhIRT 2)l293d motor controller - http://amzn.to/2yoq5T7 3)distance sensor- http://amzn.to/2yoq5T7 4)dc motors with wheel- http://amzn.to/2yoq5T7 5)jumper wires- http://amzn.to/2yoq5T7 6)chassis- http://amzn.to/2yoq5T7
Step 2: CIRCUIT :
here is the simple circuit diagram........
trig pin is connected to arduino 2pin
echo pin is connected to arduino 3pin
motordriver l293d have 16pin...
1,8,9,16pin of l293d is connected to +5v
4,5,10 and 11 pin of l293d is connected to gnd
so..
2pin of l293d is connect to 4pin of arduino
7pin of arduino is connect to 5pin of arduino
9pin of arduino is connect to 6pin of arduino
15pin of arduino is connect to 7pin of arduino
motor1 is connected to 3 and 6pin of l293d
motor2 is connected to 10 and 14 pin of l293d
that it....then connect to power supply....
Step 3: How This Robot Works??
this robot is works depend on ultrasonic sensor,which is help to find any object in range...
ultrasonic sensor works in 180degree angle...
so if distance of ultrasonic sensor 25cm or <25
this time robot moves forward using two dc gear motor...
else ..if distance <25..this time robots can moves backward..
if(distance>=25)
digitalWrite(m11,HIGH);
digitalWrite(m11,LOW);
delay(400);
else
delay(400);
if(distance>=40)
delay(500);}
if distance is 40cm or >40..then robots will be stop
Step 4: Uploading Code
plz copy the code below and paste it in your arduino..
#define trigpin 2
#define echopin 3
int m11=4;
int m12=5;
int m21=6;
int m22=7;
void setup()
pinMode(m11,OUTPUT);
pinMode(m12,OUTPUT);
pinMode(m21,OUTPUT);
pinMode(m22,OUTPUT);
pinMode(trigpin,OUTPUT);
pinMode(echopin,INPUT);
void loop()
int duration,distance;
digitalWrite(trigpin,HIGH);
delayMicroseconds(1000);
digitalWrite(trigpin,LOW);
duration=pulseIn(echopin,HIGH);
distance=(duration/2)/29.1;
if(distance>=40)
delay(500);
else
if(distance>=25)
delay(400);
else
delay(400);
Step 5: TURN ON THE POWER AND ENJOY
FOR VIDEO ASSITANCE KINDLY VISIT OUR YOUTUBE TO WATCH FREELY AND MAKE IT WITHIN 4 MINUTES WITH CONCEPT.
YOUTUBE - https://youtu.be/8WKsG0Buj-Y
