Introduction: OLD HARD DISK AS a SOLDERING BASE
About: I like to invent and modify things. When i was 13 i fixed my dad's old Lancia Fulvia motor. I builded my first mod PC in 1991 using a mobo builded in a VCR box. I am first using all my inventions. I love every…
The idea is to have a solid and a heavy soledring base, with all we need when we work. We need an old and nonfunctional 3,5' hard disk. Also we need a star shaped screwdriver special for hard disk screws. Here in Greece i found the TB X 50 but i don't know if it's the same elsewhere.
So, we take them off all six on the top and we remove the upper cover. We will need the under cover so we have some work to do. With the same screwdriver we remove the circuit from the bottom, and the rotor with the disks . The purpose is to get the undercover only .
Step 1: The Undercover
Now after hard work we got the black under cover of our hard disk. Now before we proceed i will so you the general idea of our project.
Something like that in the image below. The hard disk undercover give us a lot o space to put some extra things like the sponge, the soldering gel (i know there's a hole there!!!) and some soldering wire, and the same the soldering gun.
Step 2: Building the Solderin Base
Ok, now we need a long spring for our soldering gun. We have two options. 1. We make it using a havy duty steel wire of diameter 2mm.or 2. we buy it ready from our local electronics supply store.
I know the image is blur (i sould use the tripod) but you get the whole idea.
Now we need the screws to hold the soldering holder to the hard disk under cover.
I used the screws like the image below. The butterfly shaped screw goes on top.
After the mouning of the soldering holder our solderin base looks like the image below.
Step 3: Some Extra Things to Make the Perfect Job.
Now our soldering base its done .But we need to add some extra things to make it working better...:)))
Ok, first we need the sponge. You can buy it or make it from mam's old sponge. There's plenty room in our soldering base to place the sponge but i gave an idea in the previous steps. What else we need? Oh yes the soldering gel. i use it a lot, so was annoying to open the box and close it again and again.
So i took the aluminum case from a small candle and i put the appropriate amount of soldering gel and i put it in the hole of our soldering base like i so you in the first step. Now i work fine, and always i have my soldering gel in use....
I hope enjoy it this easy project as i do. The purpose was to get a solid soldering base.
Thanks all you read this...
also my excuses for my bad English...
bye Agis
