Introduction: OPTIMUS ROBO
“OPTIMUS ROBO” means a robot can effectively use for different works and can perform various functions at a time.
“OPTIMUS ROBO” consist of four different parts assemble on vehicle
1) PICK & PLACE ARM
2) WOOD-CUTTER
3) VEHICLE (TANK)
4) CONTROL SYSTEM(REMOTE CONTROL)
PICK & PLACE ARM :- This is the FOUR motor-driven robot arms. Since the arm has a few joints, we can imagine our human arm in addition to shoulder, elbow, wrist & coupled with the finger joints. It is assembled on moving vehicle i.e.(tank). It can be used for picking the object and place wherever we want it.
WOOD-CUTTER :- As everyone know that cutter which is use to cut the wood, which are useful for cutting different type of wood from surrounding (under thickness 3 mm) which is helpful for mankind for their respective works. Wood cutter consist of one cutter blade, gears & its mechanisms, motor (1000 RPM), bearing parts.
VEHICLE (TANK) :- Vehicle give’s an perfect mounting for all sub-parts of ROBO. vehicle is important part in “OPTIMUS ROBO” due to their movement along with all component it provide flexibility for working parts. Tank can rotate at 360 degree at same position.
REMOTE CONTROL :- Which controls the system of “OPTIMUS ROBO” with the help of limit switches, connection of wire is done from remote control to ROBO. This remote control is operated by human to do specific work
Step 1: Construction of TANK
Working Requirement:-
1. Electricity connection :-
12V 1.3 Ampere Power Supply
SET-UP:-
Tank:-
Plywood of 400x300mm is cut by hex-saw.
Plywood is cut in shape of ‘I’.
4 Nos. of D.C. Motors are clamped below the four corner of plywood at the same height.
4 Nos. of wheels are attached to each of the motor.
3 Nos. bearings are fitted by nuts & bolts on both sides to avoid the slipness & to get the grip to the wheels.
Belts are mounted on two wheels on both the sides.
Step 2: Construction of CUTTER
Cutter :-
On the front side of the tank the wood cutter is attached with helical gear mechanism.
Motor of 1000rpm is clamped by nut & bolt.
Large helical gear is attached to motor.
Small helical gear is attached to wood cutter.
The wood cutter is supported by shaft at two ends.
Larger gear & small gear are engaged with each to rotate the cutter which helps to increase the speed of cutter.
Step 3: Construction of PICK & PLACE ARM
Pick & place arm:-
On the opposite side to the cutter pick & place arm mechanism is attached by 3.5 rpm D.C. motor which is attached to the plywood, perpendicular such that the rotation of pick & place arm will be 180 degree.
On the moving plywood two clamps are fitted by nut & bolt which supports the shoulder
D.C. motor of 10 rpm is clamped to moving plywood which is perpendicular to
clamp the warm gear is attached to the shaft of D.C. motor which helps to move the
shoulder up & down by warm & spur gear mechanism.
In the same way of shoulder elbow is fitted at the end of the shoulder to the end of
elbow 10rpm D.C. motor is clamped to the function of gripping.
Power screw is attached to the D.C. motor which act as closing & opening the gripper
shape of gripper is like ‘x’
Step 4: Electrical Connection
Electrical connection:-
Battery is attached below the tank.
Electrical Circuit is fitted above the tank at the centre through which 16 colour band wire is given to the remote in which 6 limit switch & one On-Off switch is fitted & these wires are connected to switches to perform their function
