Introduction: ORIGAMI SKULL MASK
About: CRAFTSMAN
Hi guys,
October is coming with Halloween, and Halloween is coming with scary things.
Skull masks are remembered for scary things.
I did it myself with help of the origami method.
Let's start to do it.
-Black and White papers (90 GSM),
-Pencil,
-scale,
-paper knife,
-paper clips (6),
-Glue (Fevicol),
-Must need patience crafter.
Step 1: ORIGAMI PAPER PIECES (MODULES)
2.5''×1.5''(INCH) rectangular piece of paper is used to make origami modules.
Step 2: PAPER CUTTING
★Take 1.5'' lengthwise and 2.5'' breadth-wise in A4 sheets In this, we can get 23 rectangular pieces of paper (23/1).
★Stack 10 sheets of paper and clip them.
★By using a paper knife cut them away.
Step 3: RELAX & FOLD, RELAX & FOLD, RELAX & FOLD.......
1, start with a half-fold lengthwise,
2, Then half-fold in breadth wise,
3, Fold the right side of the paper to the half-fold line in the middle,
4, Do the same, 3rd step on the left side,
5, Turnover, fold down the right corner,
6, Fold the right flap down,
7, Do the same 5&6th step on the left side,
8, Fold the left flap down, you'll end up with a triangle,
9, Again fold in half and you are done.
-To start, make about 500 to 600 triangular modules,
-Don't worry about the quantity, just start folding and after a day or two, you'll accumulate enough pieces.
Step 4: PRE-INSERTION
* Insert that folded pieces in the column(one by one),
* Do this, that tightens pockets of modules that are just expanding,
* Now inserting in the skull is easier,
* Stack 10 modules in the column.
Step 5: HOW TO INSERT MODULES (BASIC METHOD)
★ Always remember that, insert modules in rows(one next one),
★ Insert the left arm of the second piece into the right pocket of the first piece,
★ Insert the right arm of the second piece into a left pocket and the third piece,
★ Continue like these and form a row.
Step 6: TOP HEAD
★ Start with 2 rows of 40 modules in each,
★ Then add modules in the basic method up to the 10th row,
★ After the 10th row, bend the structure evenly applying pressure from two hands,
★ Finally add two more rows of modules.
Step 7: OVERALL GLUING
Glueing in every single module is a frustrating job and also takes lots of time to complete. To avoid this, overall glueing inside the structure is good.
Step 8: FACE
FOREHEAD:
=Make 15 columns and 5 rows with white modules to form the forehead.
EYEBALLS:
=After the forehead, start to form eyeballs by using black modules,
=Insert black modules in the 2,3,4,5,4,5,4,3,2 method and remaining as white modules.
NOSE:
=Insert black modules in 2,3,4,5,6,5,4 methods and remain in white modules.
TEETH:
=Insert black modules in the lineup and end with white modules.
Step 9: GLUING
Don't forget to apply glue, after completing the forehead, eyeballs, nose and teeth.
Step 10: IN FINAL COUNT
To finish up the skull mask you'll need a white 690 and a black 126 of a totally of 816 modules.
