Introduction: OSOYOO Yun IoT Smart Home Kit for Arduino
This is a great kit for you to learn about IoT(internet of things) and apply many smart home devices.
The kit is based around OSOYOO Mega Board — compatible with Arduino Mega2560 R3 and the Yun Shield — enables Makers to add connectivity to their designs. The OSOYOO mega2560+Yun Shield is similar to Arduino Yun board, as well there are more available pins.
Step 1: Authorized Online Retailers
Step 2: Tutorial and Sample Projects
You can see the following tutorial from: http://osoyoo.com/?p=15678
Lesson 1 What is Arduino?
Lesson 2 Osoyoo Mega2560 Board
Lesson 3 Osoyoo Uno vs Osoyoo Mega 2560
Lesson 4 What is Yun Shield ?
Lesson 5 How to use the Yun Shield with Arduino?
Lesson 6 What is Blynk ?
Lesson 7 Getting Started with Blynk
Lesson 8 Model Installation
Lesson 9 Remote Control a LED Blink
Lesson 10 Remote Control a Buzzer
Lesson 11 Remote detection the State of Flame Sensor
Lesson 12 Remote Control Relay
Lesson 13 Remote Control the SG90 Servo
Lesson 14 Remote Control the RGB Module
Lesson 15 Remote detection the state MQ2 Gas Sensor
Lesson 16 Photoresistor and Ultrasonic HC-SR04
Lesson 17 PIR Motion Sensor
Lesson 18 RFID Module
Lesson 19 Remote Display Message on I2C 1602 LCD
Lesson 20 Remote Access to DHT11 Data
Lesson 21 4×4 Keypad Password lock
Lesson 22 Osoyoo IoT Yun Smarthome System
Step 3: Remote Control a LED Blink -- IoT Smart Home Tutorial
In this lesson, we will show how to use the Osoyoo Yun IoT Kit with the Blynk APP to control a LED.
Preparations
HARDWARE
Arduino(Osoyoo Mega2560 here) x 1
Dragino Yun Shield x 1
Breadboard x 1
LED x 1200Ω
Resistor x 1
Jumpers
SOFTWARE
Arduino IDE (version 1.6.4+)
Blynk APP
Blynk library (Click this link for How to install additional Arduino Libraries)
Connection
Build the circuit as the picture 2 shows.
Code Program
After above operations are completed, make sure that the Yun Shield is on the same network with the computer. Open the Arduino IDE and choose corresponding board type and port type for you project. Then load up the sketch onto your Arduino.
In this example sketch, find this line:
char auth[] ="YourAuthToken";
This is the Auth Token that you emailed yourself. Please check your email and copy it, then paste it inside the quotation marks.
It should look similar to this:
char auth[] = "f45626c103a94983b469637978b0c78a";
Upload the sketch to the board. Wait until you see something like this:
avrdude done. Thank you.
Congrats! You are all set! Now your hardware is connected to the Blynk Cloud!
Add a Widget
Your project canvas is empty, let’s add a button to control our LED.
Tap anywhere on the canvas to open the widget box. All the available widgets are located here. Now pick a button.
Widget Box shows as the picture 3 shows.
Drag-n-Drop - Tap and hold the Widget to drag it to the new position.
Widget Settings - Each Widget has it’s own settings. Tap on the widget to get to them.
The most important parameter to set is PIN . The list of pins reflects physical pins defined by your hardware. If your LED is connected to Digital Pin 8 - then select D8 (D - stands for Digital).
Running Result
After you finished all above operations,open the Serial Monitor and you will see the connection situation,then open the Blynk APP, press the PLAY button. This will switch you from EDIT mode to PLAY mode where you can interact with the hardware. While in PLAY mode, you won’t be able to drag or set up new widgets, press STOP and get back to EDIT mode.
At the same time, you can see the hardware side as the .gif picture shows.
