Introduction: Chopping Board
Made from left over oak flooring . Cut a section of ply to the size I wanted my chopping board then layed out blocks on 45 degree angles and marked against ply to get my angles
Step 1: Chopping Board
After I cut all the blocks to size I sanded off rough edges and glues blocks together using my piece of ply wood as my guide. After all glued I left for 24hrs
Step 2: Chopping Board
After it was left for 24hrs to settle I sanded both faces then ran the decrotive edge around the board with a router . Then to finish off drilled the hole with a 32mm hole cutter then sanders with fine sand paper
