Introduction: Object Avoidence Robot
This is a robot which avoids obstacles
needs tinkercad (website)
Step 1:
First you need to add 2 components 1 is Breadboard and another Arduino Uno R3
Step 2:
Add a H-Bridge Motor Driver
You can Find it as H-Bridge Motor Driver or L293D
Step 3:
Now u need to add 2 wires . 1 from 5v to the upper +(plus) line and another from GND to -(minus) line and use the GND Which I used
Step 4:
Now only upper lines are getting battery so for the bottom lines to also get battery we need to connect a wire from upper +(plus) to lower +(plus) and from upper -(minus) to lower -(minus)
Even change colors like I have did
Step 5:
From H-Bridge Motor Driver take wires
From Power 1 to +(plus) line
From Enable 3 &4 to +(plus) line
From Enable 1 & 2 to +(plus) line
From Power 2 to +(plus) line
Step 6:
FromH-Bridge Motor Driver all 4 grounds to - (minus) line
Step 7:
Add 2 motors and align them
Upper motor as Right Motor
Lower Motor as Left Motor
You can find motors as Hobby Geramotor
Step 8:
Now connect right Motor's positive wire to output 3 and negative in output 4
Now also connect left Motor's positive wire to output 1 and negative in output 2
Step 9:
Now you need to connect both upper and lower wires . Upper wires in D8 and D9 . Upper wires in D10 and D12.
Step 10:
Now click on code and code blocks like this
Step 11:
Now add Ultrasonic Distance Sensor from other components
Step 12:
Now VCC Wire from Ultrasonic Distance Sensor in +(plus) row
Now GND Wire from Ultrasonic Distance Sensor in -(minus) row
Now Trigger Wire from Ultrasonic Distance Sensor D7
Now Echo Wire from Ultrasonic Distance Sensor D6
Step 13:
Delete All Blocks
Step 14:
The blocks should be like this and when u add the sign it should be < and in number 5 rest blocks u have seen
Step 15: Working Video
Steps Complete
