Introduction: Oceanside Kitty Duplex
Durable cardboard based two-level cat condo. Has luxurious topside bedding surrounded by baby proof, height extended walling. Inside feature two privacy windows and kitty exclusive entry door. All ocean themed and a perfect kitty getaway by the sea.
Step 1: Cut 3 Circular Bases, Short Inner Support Wall, Taller Outer Support Wall.
Measure based on cat size.
Step 2: Cut PVC Pipe As Support Height of Inner Support Wall.
Cover or paint pvc pipes as preferred
Step 3: Glue Smaller Support Wall Onto Bottom Circular Base
Apply plenty of glue as base support
Step 4: Cut Windows, Match Measurements on Both Support Walls
Don't forget to glue plastic layer of choice between shorter support wall and taller support wall.
Step 5: Glue Outer Support Wall Over Lower Support
Cut out entry hole to match over shorter support walls entry hole.
Step 6: Glue 2nd Circular Base Onto Pvc Pipes and Shorter Support Wall.
Create enclosure by using glue to seal extra spots.
Step 7: Place 3rd Circular Base on Top for Extra Support
Place 3rd base on top, glue if preferred, and place cat bed on top.
Step 8: Paint and Accessorize
Finish outer design, add toys, beds, etc.
