Introduction: Odroid U3 LAMP Server With Seafile Cloud
Please Vote for this Instructable and some of my others in the Vote section in the top right hand corner of the page. Thank you very much for supporting our projects and I hope they are helpful.
In the world of microcomputers the story has been severely limited processing power. We can overclock our RPI and BBB but these lead to premature hardware failure, operational instability and other issues. There have been wonder boards promised like parallella but there are some great boards that are have been out for the last year and they are great. There is the Banana Pi, Hummingbird Pi, and the Odroid line of microcomputers. We will be using the Odroid U3. It is a 1.7GHz Quadcore A9 Cortex Processor with 2 GB of DDR3 RAM and a 16GB EMMC card for the boot drive. This should be a pretty capable board for our personal web server with our own cloud. This will be a great server for hosting a blog, small business server or family media server. I will be adding an older 250 GB One Touch Mini Maxtor USB hard drive. I have some larger capacity drives for my main server. I am using this as a lab server for a few ongoing projects that I have going on.
This tutorial is really about the initial installation and setup of a LAMP stack server on an inexpensive low energy high performance linux computer with a personal cloud service. I am just getting into linux over the last year and have had to piece all of together from several tutorials for other boards to get it all working on the Odroid U3. I also had to change the order of a few steps to get it to configure right so that everything would work. Some steps can be out of order after the Seafile Server is installed and running but the setting up the sql database and installing seafile before anything else was crucial to me getting the server working properly. As this is set up for an internal network server we will not be covering DDNS in this tutorial. I am really just trying to show the initial installation of the program to get it to work on my netgear router network with Clear internet service.
Step 1: Items Needed to Complete This Project
The item list for this project is fairly short. I will explain what it is that I am using and what parts are interchangeable or optional. This can be setup headless or with a monitor if you would like. I prefer to look at the first boot on the monitor.
Odroid U3 Microcomputer
HDMI Cable with Micro HDMI or an Adapter
Ethernet Cable
5V Micro USB Phone Charger at least 750 mA
16 GB eMMC or SD Card (or larger up to 64 GB)
250 GB One Touch Mini USB HDD (You can use any Linux compatible HDD. I am not testing others at this time this is the one I used for my development setup. I will talk more about it in a few steps when we prep the drive.)
(optional items)
monitor
keyboard/ mouse
Step 2: Download and Image the EMMC Card or an SD Card
This step is just downloading and imaging the card. I use SD formatter to be able to format the cards and WinDisk Imager. I do not want to go into to much detail as there are lots of tutorials on how to do this. If you are working on a net server then you should know how to do this part by now. Below is a link to the image as of June this year for Unbuntu on Odroid. This tutorial is specifically for the Odroid with Arm processors. This image will not work with Windows or Mac machines. There are plenty of Unbuntu images for those processors.
Step 3: First Boot of the Odroid U3
This is a simple step. While the Odroid can be started headless and is ready for ssh on first boot I like to have the Desktop up for a few early changes. So plug in the eMMC or SD card, monitor, usb dongle for keyboard and mouse, ethernet cable and finally power.
*I will note here that it is not wise to plug in a blank SD card at this point. I had thought since I have an eMMC card that I would use a high capacity card as a drive. Before this can happen you have to do a little drive priority maintenance. It will not boot up the eMMC drive with an SD card in. I will not be covering that in this tutorial. I may come back to this in the future as an update.
If you have to enter a password or user they are as follows
User = odroid
Password = odroid
The Odroid boots fast and boots into the desktop immediately. The first think I do is run the odroid utility which seems to be Odroids version of the raspi-config command on Raspberry Pi. It is not very robust but I usually choose to change the hostname. We will not for this tutorial because we are just setting up a development web server and not covering network security. Aside from changing host name we will also expand the root partition and get some updated xorg files for the desktop. If we were sticking with the desktop we would also change the windows manager but since we are not we will skip that part. When you are finished with this step you can reboot so that changes will take effect.
On reboot we will then start a terminal so we can check a few things and make a few short changes.
First run the command
sudo ifconfig
we can check our internet connection. We are mainly looking for eth0 and what the IP address is. We may need some of the other parameters but we can check them later. Make a note of your IP address.
next enter the command
sudo dpkg-reconfigure keyboard-configuration
This command will let us choose our keyboard for our configuration. Choose the UTF8 configuration for your country. Use the spacebar to deselect the default and to select the keyboard configuration of your choosing.
next we will enter the command:
sudo dpkg-reconfigure tzdata
This command is so that we can choose our own timezone. This is pretty self explanatory.
Next we will run the command line:
sudo nano /etc/ssh/sshd.conf
This will bring up the nano editor so you can make changes to the script. In my image I have found that nano is not installed you can switch nano for the vi command if you are comfortable with the vi editor. If the nano editor is not there then run the command line:
sudo apt-get install nano
Then rerun the command line:
scroll down till you see the lines
port# = 22 (make sure this is set to 22 for our initial setup but for security you can change the port later)
protocol 2 (I am not sure what this is but it is supposed to be on 2)
permit root login = YES (make sure this is yes for now but again for security you will want to change this to NO later)
Hit Ctrl X then y then enter to exit and save the file.
Let's bind the IP address by the following commands:
ifdown eth0
ifup eth0
Make note of the IP Address
In the command line type:
sudo reboot
Step 4: Connecting and Configuring the External HDD
In this step we are going to connect the hard disk drive. Most of these drives have a management and security software on them. We will be eliminating this probably. Some of the new drives may boot right up and be available for immidiate use by the Odroid. My Maxtor was not. It is real simple to check. When you plug in the drive the Unbuntu Desktop should have a prompt to open in file manager. We want to see the drive path for later. In mine it boots in the home directory /media/odroid/OneTouch 4\Mini. We will be making changes including the drive name. you can even move where the drive mounts but this is fine for our purposes.
Next we will open a terminal.
Type the command:
cat /proc/mounts
this will give us a list of the drives that are mounted. We will ignore the ones that root or boot drives ending in mmc. We are looking for the drive that has /dev/sda*. The * is probably going to be a partition number 1. If there are multiple partitions mounted then we will see them listed in order. If you were to have a flash drive in also it would probably show up as /dev/sdb and so on.
Next we want to see if the drive is usable as it is formatted or if we are going to have to rewrite the drive.
Type the command:
sudo nano mkdir /media/odroid/OneTouch 4\Mini/test
You will be using the drive path that is you found in the file manager on the desktop and only adding "test" to make a file if it will write compatible with the Odroid. If you get a read only error then you will have to reformat which is a few simple steps. There are several ways to go about this but we are going to use a program called parted. Be very careful and pay attention to what you are doing. This can wreck not only the OS but he board as well so be very careful when working with the drive scripts.
First issue the command:
umount /dev/sda1
This will unmount the partition so that we do not get an in use error.
next type:
parted
this will start the parted program
Then type the command:
select /dev/sda
This is very important to make sure we are in the right drive. We do not want to mess with the boot drive at all.
Next we will type the command:
mklabel msdos
You will be prompted to give a name to the drive. I will call mine labserv since it is for a server for my laboratory.
next type the command:
mkpart
when prompted respond with the following answers
primary
ext4
0%
100%
This is the partition layout you can change these values if you wish to make multiple partitions but for our purposes here we will only be writing the one partition.
Type:
to check the partition has been written properly
and exit the editor by typing:
quit
We are almost finished making the drive work for our server. Let's write a file system to the partition.
Type the command:
mke2fs -v -L labserv -t ext4 /dev/sda1
This will write the file system to the drive. When this is done we can test it in a few moments.
Type:
umount /dev/sda
Then unplug the drive from the usb. Wait just a moment then plug the drive back in.
Check the file manager to see the drive path for the HDD. Mine now reads /media/odroid/labserv
Type the command:
mkdir /media/odroid/labserv/test
If there are no errors then we can remove the test folder by typing:
rm /media/odroid/labserv/test
Congratulations, we have formatted the drive and prepared the partition and file system for our use with the server. Shutdown the Odroid so that you can unplug the monitor and keyboard. This can be done through the gui or type the command in the terminal
sudo halt
Step 5: Logging in With SSH and Installing MySQL
We need to log in through SSH. I am not going into too much detail here as there are lots of tutorials on the specifics. I use Putty for my terminal connection. Just install the free software and then initialize the program. You will be asked for the IP address and make sure the port is set to 22. Hit enter and a terminal window will appear. We want to log in as odroid with the password odroid. You should basically have the same terminal you would see on the gui. with the command prompt odroid@odroid~$ This means that you are in your home directory.
We have made a few changes so we want to run the command:
sudo apt-get update
sudo apt-get upgrade
answer y when prompted.
We are now going to install the mysql by running the command:
sudo apt-get install mysql-server mysql-client php5-mysql
you will be prompted to set a password for the user "root" do so when asked
we need to run two more commands:
sudo mysql_installation_db
sudo mysql_server_installation
just type y for each of the answers except changing the root user password answer no. We should now be ready to install the Seafile cloud software in the next step.
-->Step 6: Installing and Using the Seafile Server Software
There are two dependencies that the software may ask for during install so we are going to preempt this error by installing the last of the prerequisite software libraries.
type the command:
sudo apt-get install python-setuptools python-simplejson
Answer y if prompted
Now we are ready to install the Seafile Server. This will allow a nice interface to your server through your browser window.
Let's first create a directory seafile by the following command:
mkdir seafile
then change directories:
cd seafile
now we are ready to download the package into the directory seafile:
wget hhtps://bitbucket.org/haiwen/seafile/downloads/seafile-server_3.0.4_pi.tar.gz
and untar the package:
tar xzvf seafile_server*
change directories:
cd seafile_server*
then install the software:
.setup-seafile-mysql.sh
you will follow the prompts here and just choose defaults except for two things:
when asked for server name choose you server name
Enter your IP address
choose the default ports but then you want to direct the data to your drive you setup earlier. My drive path is /media/odroid/labserv/seafile-data
Choose to setup new mysql databases. After all the questions are answered you should have a setup list that looks like this
Server Name: Your Server Name
IPAddress: Your IP
ccnet server port: 10001
seafile data: /media/odroid/labserv/seafile-data
seafile server: 12001
HTTP server: 8082
MySQL server: 3306
ccnet database: ccnet-db
seafile database: ccnet-db
seahub database: seahub-db
During the setup you may be asked to enter to the mysql root password you set earlier
Now we are going to start seafile server and seahub first type the command:
./seafile.sh
It should start and tell you it is ok then type:
./seahub.sh
you should be asked to enter the administrative email which should be any email you want and then set a password for the browser login just enter those and remember them. The Seahub should setup for the first time and run fine. You can now check it in your chrome browser by typing:
http:yourip:8000
just login and check out your new cloud server
Step 7: Installing Apache and PHP
We already have a linux and mysql installed on the Odroid. We need two more pieces to make the LAMP Server complete. The A and the P stand for Apache and Perl, PHP, Python.
sudo apt-get update
Install Apache and PHP:
sudo apt-get install apache2 php5 libapache2-mod-php5
we need to enable the htaccess type:
sudo nano /etc/apache2/apache2.conf
under htaccess change Require all denied to Require all granted
restart apache with the command:
sudo service apache2 restart
we need to change one more file:
sudo nano /var/www/html/info.php
then type this in the file:
<?php
phpinfo();
Now we are able to check both the apache and php servers. In your browser type the following URL's
http://your ip
you should see the apache start page or a page that says it works but there is not content next you can type: http://yourip/info.php
you should be able to see the php information page
Step 8: Installing FTP Server
We have one last software that we would like to add to our server. We have now completed a LAMP server with Seafile personal cloud service but there is one more piece I would like to add to make for a robust development server. We are going to add an FTP server. First we need to change ownership of the /var/www file.
Type the command:
sudo chown -R odroid /var/www
Next install vsftpd by the command:
sudo apt-get install vsftpd
then we need to change the configuration file with the command:
sudo nano /etc/vsftpd
change anonymous_enable to YES
uncomment local_enable and write_enable
then add the following lines to the bottom of the file
force-dot-files=YES
Ctrl x y and enter to save
sudo service vsftpd restart
Finally we can check to make sure the FTP server is running properly. Open Filezilla and enter the IP address, user, password and port 21. Log in to the server. It should log right in. You can move files and manipulate directories to make sure it is all working.
Step 9: CONGRATULATIONS!!! You Are the Proud Owner of a Server
This took a short while but you have a the makings of a great server. This is setup to work within your LAN while you learn how to use the server and implement security measures that you will want in place before you go live with a blog or personal webpage. I will be installing Roundcube mail service, MyAdmin, and No-IP as my DDNS. There are lots of ways to go about this. I want to publish this so I will be updating with screenshots and other things soon. I hope this helps. You can follow almost all the same instructions for installing on a Raspberry Pi as well. Thank you for checking out my instructable and I hope that it helps.
Step 10: Installing PhpMyAdmin
In this step we are going to add phpMyAdmin. This software is a GUI for our browser that enables us to manage our mySQL databases. We are able to setup users, passwords, permissions, manage databases and most everything else you can do from the command line for mysql. Let's get started.
Enter the command:
sudo apt-get install phpmyadmin
You will be asked to some questions during the setup
1. Select Apache as your server
2. Choose Yes to configure the database for phpMyAdmin
3. Enter your mySQL password
4. Make a password and confirm for phpMyAdmin
Next we need to add the phpMyAdmin configurations to the configuration file in Apache.
Enter the command:
At the bottom of the file add the following line
Include /etc/phpmyadmin/apache2.conf
Ctrl X, y and enter
Restart Apache with the following command:
Now you want to enter youripaddress/phpmyadmin in the address bar of your browser. The phpMyAdmin page should come up in your browser. Enter your mySQL password and it will load up GUI for your mySQL databases.
