Introduction: Offset BBQ Smoker. Wood Burning BBQ Temperature Controller (with Variable Speed Fan)
After visiting Memphis and loving the blues and slow cooked BBQ I decided to build an offset BBQ when returning back home. I cut up an old LPG car fuel tank and had a local company profile cut sides for a firebox, as well as hinges etc. I welded it all together and painted it with hi temp black paint.
Several times using it, I found that too much time is spent mucking about with keeping steady temperature. This wasn't helped by poor design of my air intake. I think it was not placed low enough below the fire grate level.
After looking on the web for ready made automated solutions I found that (at least for a stick burner) there was not too many options.....even less so available locally in Australia. With not wanting to buy a pellet smoker i thought id have a crack building my own fan forced PID temperature controller. After a bit of trial and error this is the final version. With my large firebox (slightly bigger than advised by Feldons Calc) I find I can add at least a couple of hours worth of dry wood/fuel and let the controller / variable speed fan speed do the work.
Using the rotary encoder, there are adjustable temperature, low temp alarm, high temperature mode and PID setpoints. These will store in the EEPROM once adjusted so that they become the default on powerup of the unit. Anyone having a crack at this will have to build some form of ducting to get the fans output to the firebox....I used 40x40mm square tube and a custom bracket. with the fan running (even pulsing in hi temp mode) not much heat transfer occurs along the duct so anything that keeps fan far enough away from the firebox's radiant heat should suffice.
  1. low alarm - buzzer will sound to alert wood fire needs more fuel
  2. low alarm silence button - will silence alarm to give fire time to recover temperature once fuel added (10 minutes)
  3. high temp mode - will pulse fan at lowest speed on/off to help drop temperature
  4. PID control - offers adjustable PID constants to help with tuning
  5. Arduino sketch is set up as Celsius initially, however if button on Pin8 is pressed on powerup then default will toggle to Fahrenheit and save in EEPROM.
Build as per schematic using a suitable PVC enclosure that will allow easy view of LCD display.
*********UPDATE: Built a new BBQ. Old one too small. New photos attached. New one has bigger firebox and cook chamber. I used same design Air Blower as that works so well. I have attached the DXF files for the mild steel components. I sent these files to local firm who laser cut the 5mm Mild Steel and rolled the chamber. Then I welded it all up. All parts fit together no problems so there was minimal angle grinding and adjustment...really just cutting the Chamber Lid out and some incidental parts/angle iron/Smokestack (150mm x 150mm Square Mild Steel tube). The most difficult part was using straps to tighten the rolled chamber so i could weld a seam along the join and ensure it circular...as it wasn't completely rolled edge to edge i think.
  1. Arduino Uno
  2. make sure all the libraries required in the ino file are installed to your Arduino IDE
  3. 12vdc 4 (or 3) wire PC Fan (at least 25cfm).
  4. 20x4 LCD Display
  5. 2 Channel Arduino Relay
  6. 12vdc Piezo Buzzer
  7. MAXX6675 Thermocouple and probe module
  8. 12vdc switchmode power supply (with additional 12vdc > 5vdc converter)
  9. Generic laptop power supply with 12vdc output selected is ideal
  10. Rotary Encoder with Push Button switch
  11. 1 Normally Open / momentary switch
  12. solder/wire etc
  13. Optional 10K Variable resistor
  14. Suitable enclosure with clear cover (to view LCD display)
  15. Using SHS steel section, build a short duct to direct air from fan to bottom of the firebox
Step 1:
My 1st instructable. didnt take much progress pics. however should be enough above if you keen enough to get started/complete.
