Introduction: Ogle Carburetor Prototype
This is a device that vaporizes gas much like the Ogle carburetor did. This is very easy to make, and it works. Make sure you have hot glue. You will need it.
Also remember: This is just a prototype, so use JB Weld if your going to make a permanent device. The glue will come loose (speaking from experience here.).
Here are some videos that I took:
If you just want to watch them:
To download them, links below.
Hot Glue.
A small engine for testing (lawnmower engine, make sure it runs)
Step 1: Remove Carburetor From Engine and Attach a Hose Connector
A brass fitting will not melt, so attach it on there.
Step 2: Drill Holes in Lid
Drill 4 holes in a circular pattern near the edge of the lid and punch a 1-inch hole in the middle of the lid.
Step 3: Cut the Tubes
Cut tubes 1 inch longer than the height of the jar.
Step 4: Glue the Fitting and Tubes
Glue the plastic fitting on the 1-inch hole in the lid, and the tubes into the smaller holes on the side of the lid with about 1 cm of space from the bottom of the jar. If you want a permanent solution, use JB Weld. or silicon maybe.
Step 5: Connect Everything
Fill with gas and attach the device to motor with the tube. Give it a few cranks. You may need to give it a little air too.
