Old Book= New Sketchbook!!
Intro: Old Book= New Sketchbook!!
Ever wanted a unique sketchbook project for your high schoolers? A new journal for yourself? A gift for a family member or friend? All without spending a lot of money? Then this project is for you!!
Students creating this project will learn how to recycle/ reuse an old discarded book, how to use sewing (coptic/chain stitching) to link pages together, and how to create a sketchbook that is unique to them and that can be used for so many things!
Materials needed:
Old book
Exacto Knife/ Box Cutter
Computer Paper
Strong Thread/ Waxed Linen
Embroidery Needle or Curved Needle
Sharp Object (Seam Ripper, Safety Pin, Paper Clip, etc.)
Cardstock
Spray Adhesive or Rubber Cement
Paint or other art materials to decorate cover with
Materials needed:
Old book
Computer Paper
Cardstock
STEP 1: Find a Book!
Find an old book!
I found a bunch at an old book relief sale, but you can find them in your own house, at library sales, thrift stores, or garage sales.
STEP 2: Cut Along Binding
Using an Exacto Knife or Box Cutter, make a slit along the first page of the inside of the book. Repeat with the last page.
STEP 3: Remove Pages
The pages should come out very cleanly, all connected!
STEP 4: Measure Pages
Measure the height of the pages you removed. This will be the height of the pages you will need to cut. Measure the width of the pages, and multiply that by two (since our new pages will be folded in half), this will be the width of your new paper.
My pages were 8 inches by 5.5 inches, so my new papers will be cut to 8 inches by 11 inches.
STEP 5: Cut New Pages
Cut computer paper to the height of you old pages by double the width. I used blue computer paper, but you can use any color! you can also use thicker paper, just know that you will need less than if you go with regular copy paper.
Again, my papers are being cut to 8 inches by 11 inches because my old pages measured 8 inches by 5.5 inches.
STEP 6: Fold New Pages
Fold all of your newly cut pages in half. If you do this individually, the folds will be crisper and more exact.
STEP 7: Make Signatures
A signature is a section of book pages that makes it easier to sew!
With copy paper, I usually like to fit 8 folded pieces together to make a 16 page signature.
STEP 8: Trim Signatures
Since you are fitting so many pages into a signature, your edges will probably not be very even. I always trim them up on a papercutter.
STEP 9: Cut Cardstock
You will also need a little bit of cardstock. I cut mine to one book pages size 8"x5.5" to start, and then cut that in half longways, leaving a 8"x2.75" piece.
STEP 10: Make Template
Because we want our signatures to be sewn together evenly, we need to poke some starter holes that are in the same spot in each signature. To make our "hole template" we have to fold on of our cardstock pieces in half longways.
Place the ruler on the fold and make a dot 1/2 inch from each end, a dot in the center, and two dots between the center dots and 1/2
inch dots on each side.
Use your sharp object (I used a seam ripper) to poke a hole at each dot.
STEP 11: Prepare Your Signatures
Open up your first signature and place the template into the fold. Use your sharp object to poke holes through the template and through your first signature.
Repeat for each signature.
STEP 12: Create an End Paper
Because we will be using the coptic/ chain stitch to sew our signatures together, we will need and end paper to hold it all together. Make the same measurements as you did on your hole template, and poke holes on those dots as well.
STEP 13: Sewing Part 1!
Tie a knot in the end of your thread and insert the threaded needle into the first hole from the inside of your first signature.
STEP 14: Sewing Part 2!
Place the end paper on top of the first signature and insert the needle and thread from the top down.
STEP 15: Sewing Part 3!
Go back through the first hole and back out of the second hole, both inside the first signature.
STEP 16: Sewing Part 4!
Go through the second hole in the end paper from the top like you did in the first hole. Continue this stitching process until you get to the final hole. When you go through the end paper from the top on the last hole, do not go back through the last hole in the first signature.
STEP 17: Sewing Part 5!
Instead of going back through the last hole in the first signature, put a second signature under the first, and go into the first hole of the second signature.
STEP 18: Sewing Part 6!
Bring thread out of the second hole of the second signature, and (like we did with the first signature and the end paper) insert the needle between the first signature and end paper and go back through the second hole of the second signature.
STEP 19: Sewing Part 7!
Continue this pattern until you get to the last hole in the second signature, and instead of going back through the last hole, go through the first hole of a new signature. (when on the third signature, you would thread the string between the 1st and 2nd signature each time, on the 4th signature, you would go through the 2nd and 3rd signature, and so on.) It gets easier the more you sew!
STEP 20: What If I Run Out of Thread?
Good question! If you run out of thread, simply stop sewing once you are on the inside of a signature. Take a new piece of thread, and tie it to the end of the previous thread, as close to the hole as you can. Trim the ends and you are ready to go!
STEP 21: Finish Your Sewing!
Once you are on the last hole of your last signature, simply reenter the last hole and tie the end of the thread off in a knot. Trim the excess and see how you did!
If you look at the seams of your signatures, you should see a sort of "chain" by each set of holes. This is where the nickname of "chain stitching" comes from!
STEP 22: Want a Book Ribbon?
If you would like a book mark or book ribbon for your book, simply glue the ribbon (I used a piece of lace) along the inside of your book cover before completing the next step.
STEP 23: Almost There!
To reattach your new pages to your book's hard cover, either coat the first and last page with rubber cement or spray adhesive (I used spray adhesive). Align your first and last pages with where you want them to sit on your front and back cover, and make sure the chain stitchings are snug in the book binding.
STEP 24: Have Fun!!
If you have a boring book cover, why not decorate it with acrylic paint, magazine collage, or glitter? I used pencil erasers and other circular objects to make an aboriginal dot art design on one of my covers.
STEP 25: Enjoy!
Enjoy your book, give it away, or use it in a classroom project! It's hard to stop at just one!
22 Comments
ichibon 4 years ago
ravys-art 7 years ago
I'm going to use this to make a totally customized Bullet Journal type thing! Thank you so much for this tutorial, as I've been searching for weeks on how to do this exact thing. I'll add pictures when I'm done with the whole thing.
Random Gadget Hacks 7 years ago
why do you make so hard I haven't even done it and feel tired
Book Girl 8 years ago
omicronomicron 11 years ago
tabby.barnett 9 years ago
You aren't the only one who couldn't figure out what to do with the cardstock...I guess I'll just glue it down under the back piece. Other than that, this was an awesome tutorial....I loved it!
kjellbetlem 9 years ago
Hi mcmichaelart, thats a really cool instructable! You could come and work for me, our company About Blanks does exactly that ;) We sell sketch- and notebooks made from old book covers!
mcmichaelart 9 years ago
shyanna05 10 years ago
Emmely 10 years ago
AdamVanMeter 12 years ago
Would have been even cooler if you integrated a few of the original pages of some of the books among the drawing pages, for a bit of character.
mcmichaelart 11 years ago
Nahual 11 years ago
Instructable04 12 years ago
HeavenBlueRose 11 years ago
jbpitcher 12 years ago
mcmichaelart 12 years ago
susanrm 12 years ago
