Introduction: Old Broom Handle Turned Into a Wooden Nightstick
Just showing all the steps I went through to create this weird but cool weapon or toy it just shows you don't need to throw away your old broom or mop handle make something with it
Step 1: The Measurement
First thing is to create the measurements for the main body then the handle its up to you to decide the length
Step 2: Sand and Preparing
Then I just sanded it down and marked we're all the cutting will be taking place and it was just roughly done well it was the first time making it
Step 3: Marking
And I started making on the main handle of the dowel in the middle for a guide
Step 4: Drilling
This was the trickiest because I had to cut out the centre without breaking or damaging the dowel and I was doing all this with a Dremel 300 at the time
Step 5: The Main Hole
This is the end result after spending time drilling then using a carving bit for my dremel and making a hole big enough for the sanding wheel to get in and finish the job
Step 6: Coping Saw
Then used a coping saw to cut the centre out and leave just a big enough piece to fit in the hole that I cut and sanded earlier
Step 7: Fitting Together
After that it was time for more carving and sanding just to get the thing in the hole(no pun intended)
Step 8: Glue
An when that was done I glued it all together using pva wood glue just to give it more strength
Step 9: Finally Finish
After all that I will be going back and adding a coat of vanish and doing more sanding but you can't customise it in any way possible and remember wear safety glasses
