Introduction: Old PC Fan ----> Wind Turbine in 10 Minutes
I looked at some old PC Fans I have and thought that they can be used as Small Wind Turbines.
Backyard Wind Turbines: Harness wind power with simple and fun projects
It has been my dream for a long time to make a wind turbine generator even to light an LED.
The PC Fan is Brushless DC ( BLDC) Motor. It can be converted to a generator in 5 Minutes.
This is my website:
AeroArduino.com
Here is my Channel on Youtube:
AeroArduino
I also found this little great tool on eBay for only $36 from here
Stuff you need:
PC fan : old or new from Amazon UK, Amazon DE, Amazon FR, Amazon ES, Amazon IT or eBay
Amazon Egypt (Souq), Jumia Egypt , Aliexpress
Crocodile Clips from Amazon UK, Amazon DE, Amazon FR, Amazon ES, Amazon IT or eBay
Amazon Egypt (Souq) , Aliexpress
Soldering Iron from Amazon UK, Amazon DE, Amazon FR, Amazon ES, Amazon IT or eBay
You can read this article in Arabic in my blog arabic-embedded-egypt.blogspot.com
يمكنك قراءة هذه المقالة باللغة العربية
http://arabic-embedded-egypt.blogspot.com/2014/02/blog-post.html
يمكنك قراءة هذه المقالة باللغة الإنجليزية
You can read this article in English on my blog embedded-egypt.blogspot.com
http://embedded-egypt.blogspot.com/2013/07/pc-fan-wind-turbine.html
Further and future work :
I want to try these ideas
http://en.wikiversity.org/wiki/Wind_Turbine/Howard_Community_College/Spring2012/p1502sid
http://en.wikipedia.org/wiki/Compact_wind_acceleration_turbine
Step 1: Concept
The concept is simple. You can skip this part and start directly with the conversion.
The BLDC motor used here has a stator winding and a Permanent Magnet Rotor. The motor is supplied by 12V DC. But the magnetic field rotation is generated by electronics ( Electronic Commutator ) . As the name implies , the electronics components convert DC into AC which makes the magnetic filed in the stator rotate.
The electronic commutation is achieved by a small IC.
To get the induced current from the motor used as a generator , you must remove this IC .
Step 2: Disassemble
This is what I 'll show you how.
First remove sticker on the back of the fan.
Then you 'll find a small piece of plastic lock that holds Fan shaft secured , Don't brake it. Remove it with a crocodile clip...
This crocodile clip is very useful in this job. Many people have been asking how would they remove this plastic lock and I've answered them that they can easily use the crocodile clip to do it without breaking it.
PC Fan at Jumia Egypt , eBay
Step 3: Winding Soldering
You can see 4 poles of winding connected in series and have only 2 terminals. To get the induced current , connect supply wires to those terminals and let the fanrotate.
With a solder iron , gently remove solder under IC pins and then remove the IC.
Remove any surface mount resistors or transistors.
Remove the supply wires form there place to put them in the holes of the removed IC.
Connect the supply wires in the winding terminals .
Make sure that you connect the terminals ( from which you will get the generated Voltage ) in a way that makes the two sets of winding connected in series.
PC Fan at Jumia Egypt , Aliexpress , eBay
Step 4: Final
Assemble the fan in its place and lock it with the piece of plastic I told you about.
Put back the sticker.
Connect LED terminals to the Supply wires. Don't worry about +ve and -ve terminals , the LED will light if you connect it any way , trust me.
Roll the FAN
Read My Book on Amazon
Free Windy Selfies: Have Fun Building Your Own Portable Wind Charger on The Budget
This video shows the fan in action. I connected a voltmeter to see the output voltage.
Video is in the frame on the upper photo. And you can also find it here
https://www.facebook.com/photo.php?v=10152946131930113&l=317628537734358881
Here is a video that summarizes it:
Here is the link to the project on my blog
كما يمكنك قراءة هذه المقالة باللغة العربية من على مدونتى
http://arabic-embedded-egypt.blogspot.com.eg/2014/02/blog-post.html
http://idea-arabic.blogspot.com/2014/11/blog-post_26.html
This is my new website:
AeroArduino.com
I saw a product sold on Amazon that uses the same concept to charge the phone and MP3 using the wind energy
Thank you for reading my instructable.
You can also find my book Learn By Making on Amazon website.
You can read it for free if you join Amazon Kindle Unlimited program ( Free Subscription )
Thank you for visiting our instructable.
Here are some of my latest books on Amazon.
