Introduction: Old Wine Box to Jewelry Box
If you don't know what to do with that old wine box you have lying around your house, you can turn it into a jewelry box for yourself or to give it to someone else as a gift. Here's how I did it:
Step 1: Here's What You'll Need:
a wine box
scissors
glue
sander and/or sand paper
bag
pencil
metallic pen
hotfix stones and applicator
tweezers
hook screws
paint brush
varnish
EVA foam
Step 2: Remove Unnecesary Parts
Remove the parts that you won't need and prepare the box for sanding.
Step 3: Sanding
Sand the box to a smooth finish. This will prepare it for painting.
Step 4: Varnishing
Varnish the outside and the inside of the box. Use the bag to protect the surface you are working on. Let dry according to the specifications of the manufacturer. I used a varnish with dye to make the box darker.
Step 5: Add Hooks
Draw a straight line to use as a guide for the hook screws. Measure the spacing with a ruler. This kind of wood is soft enough to drive the screws in by hand. If the wood you are using is hard or the screws thicker, you may need to make some pilot holes.
Step 6: Choose or Create a Design
Download a design or create one yourself and transfer it to the lid. I created one and then I transferred it by drawing it over and pressing the pencil hard. You can also draw it directly on the lid.
Step 7: Apply Your Design
In my case I used a metallic pen that leaves a raised finished. I then applied the small hotfix rhinestones with the applicator and the big ones with glue. Most types of glue will do.
Step 8: Closing the Box
Since I wanted the lid to open downwards, so I could use the string of the handle to hang something, I had to put some "brakes" to keep it from falling. To do so I cut a couple of strips of EVA foam and glued them in the slots where the lid slides. It took some trial and error to get to the point where it was tight enough for it to stay in place and loose enough to slide it effortlessly.
Step 9: Hanging the Box
There are many ways you can hang the box on the wall. Since I already had a screw sticking out the wall, I measured the center point in the back of the box and put a wall mount.
All that's left to do is filling it with your favourite jewelry!
2 Comments
6 years ago
That looks really nice. My wife has been wanting me to build something like this for a while. Thanks for the inspiration.
Reply 6 years ago
Thank you very much! This is my first instructable. I hope it was clear enough. I already have a ton of new ideas for new projects involving wine boxes (I have a friend in a restaurant who can provide me with many). It would be great if you could post your creation on this coment section when you make it!
