Introduction: Old School Hand Drill Overhaul.
This instructable hopes to inspire the voltage-heads out there to acquire a lo-tech backup for li-ion, ni-cad technology and then bring it up to a serviceable level. You never know - you may find that you use it more and more and electric drills less and less.
Don't get me wrong, I wouldn't be without my cordless mini-drill. Its unbranded mains voltage cousin is handy too. Both are very essential, but I discovered that sometimes it's just quicker to reach for the hand drill, put one in the chuck and start working, no hunting for chuck keys or spanners, digging out the charger and having to wait three hours etc.
The solution: Trawl the secondhand / junk / charity / goodwill shops / garage / yard sales / boot fairs for a hand drill, aka an egg-beater drill.
When choosing your drill make sure it is complete, especially the chuck jaws and springs, if anything is missing here - move on, re-manufacturing missing parts is waaaay beyond the scope of this ibble!
Check for cracks in the castings, these things have probably hit the deck a few times in their lives.
If you haven't already done so, try and give it a turn and check to see if the spindle is out of true, again move-on if there's any hint of wobble.
Step 1: Bill of Materials.
B.O.M.
1. You will need a de-greaser of some kind to shift all the gunk from the moving parts. I'll leave the exact petroleum distillate up to you, I went for White Spirit / Stoddard Solvent. It's cheap and relatively low on acute toxicity. Always read the label of whatever you go for.
2. A general purpose light oil, the sort you put on your bike chain is perfect.
3. Boiled linseed oil. Wood needs oiling too.
Now here in the UK boiled linseed oil has been treated with hot air (boiled?) which improves the drying time. Other methods of improving the drying time include the addition of heavy metals so check your countries' regulations and read the labels, if yours states heavy metal additives go for a neat beeswax polish, alternatively, and this sounds a better proposition, Zzoe recommends using food grade walnut oil.
4. Epoxy glue, Araldite or no-name, you choose.
5. An old toothbrush. A pair of vinyl gloves. What do you mean you don't have any old toothbrushes?
Step 2: Diss-assemble the Drill.
So you have your drill back in your lair, time to take it apart. If your brain works like mine, take copious notes, drawings, photographs! of how the thing is built.
Step 3: Bath Time!
Soak the parts in White Spirit for a few days. Or if you can't wait, get scrubbing now.
Just re-use a polypropylene tub or check this ibble submitted by Thav and make a
handy Small Parts Soaking Basket
Remember to make sure in polypropylene, use polystyrene and you have a mess.
Step 4: Assemble the Cleaned Chuck.
1. Get the jaws, springs and the yoke ready.
2. Place the springs in each slot and hole at the base of the yoke as per the second image of this step.
3. Hook each jaw on the end of the spring using the little hole in each jaw as in image 3 this step, it takes a steady hand. One spasm and they fall off, so lay off the coffee until after this bit.
4. Drop the yoke and jaws into the chuck shell as in image 4.
Step 5: Clean the Body of the Drill.
Scrub off the pre-soaked kack, make sure to get into the pinion teeth.
Step 6: Clean and Oil the Woodwork.
1 Give the wooden handles a wipe with a rag soaked in white spirit, as per the shaft handle (1 in the image.).
2. Apply a good libation of boiled linseed oil as per the side handle (2).
3. After 30 minutes soaking wipe off the excess and buff with a clean dry cloth as per the crank handle (3).
4.Warning. Linseed oil dries by oxidation, the reaction is exothermic and if you have any quantity of oil soaked rags lying around there is a chance that they could go pyro. Soak them down with water before disposing.
Step 7: Oil Up the Metalwork.
Wipe all the metalwork over with clean general purpose oil, put a couple of drops in the oil hole in the spindle shaft, ensure that all teeth are oiled, remove any excess.
Step 8: Replace the Shaft Handle.
Clean up the tang of the shaft. Mix the two part epoxy and apply to the tang, push the handle on while twisting to ensure even glue distribution. Leave to cure overnight if possible.
Step 9: Done.
All finished and ready for use next time there's a powerout and the li-ions aren't charged. I hope you found the instructable worthwhile and you'll go out there and do the same or better.
Sorry if you were expecting French polish, slick new paint job and gleaming metal, less is more and all that.
I've entered this in the Epilog contest and would love you to give it your vote.
Hmm, I may even take to favouring my new old hand drill just for the exercise. ;-)
Epilog Challenge
43 Comments
1 year ago
Thanks for this post. I have a drill with identical mechanics, but a different brand: GB. At least that's what is cast on the drive gear, which is not solid like your Stanley, but has "spokes", if that's the right term. Mine is in terrific shape, with no restoration needed. It has everything but the springs, and your pictures tell how they should look. I'm going to try to make replacements from paper clips.
Reply 1 year ago
Bosherston,
I made springs out of paper clips, using the yoke to shape the wire, and the pictures you posted as a guide. It worked.....so far. I'm sure there is some better wire to use, but the chuck on my drill is working well enough for the time being. I might try to get some proper spring wire later on. Thanks again for documenting and sharing your work.
5 years ago
I don't know what it is about hand drills, but every time I am at a flea market or thrift store, if there is a hand drill, I usually pick them up. I have a few rare ones, like an Ixion hand drill from Germany. This one has proved to be a challenge to restore since the handle is press fit and not wanting to come off. The chuck is also a bit of a pain. It is unlike any of my other drills. I have it soaking now in mineral spirits. Not a bad drill for $2.
Reply 2 years ago
I have a brand new one made by Draper if you remebr this Compnay!!!. But it does not trun. Want to buy it? only £10
5 years ago
Where can I buy just the chuck?
10 years ago on Step 9
Tres cool-I am missing the chuck for my old Stanley and the replacements I purchased were all the wrong size. Any suggestions?
I'm going through all of my dad's ancient handtools, stored for decades in the barn. This was very helpful, as I'd like to put them back in action!
Reply 10 years ago on Step 9
Yes! Yes,yes,yes. A marvellous course of action and please don't forget to post pictures of what you find - an Instructable too maybe?
If you find anything that gets you scratching your head as to what it could be, there's plenty of folk here who'd be glad to help - me included. Best of luck with saving the tools,
Bosh
10 years ago on Introduction
Tools Up !! Hand Drills Rules over technology.I got one and its so usefull.
12 years ago on Introduction
Just stumbled upon your ible. I have many old tools and use them all as well as my new toys. I commend you on your restoration and the fact that you did not sand blast or paint it. The value and function of a tool such as yours would be greatly reduced. I hope you get a lifetime of use out of it!
Hi!
I have a small hand drill like yours, but, it's even simpler than the one you have.
But my cuestion is...
Could i put some oil into the chuck for it to work smoother, without disassembling it?
Thanks for reading and anwering!
Goodbye!
Reply 12 years ago on Introduction
Sure give it a go ~ maybe use a can of spray oil WD40 to wash out any crud?
( Arghhh! my eyes! , my eyes! )
Thanks for reading and asking!
Goodbye!
13 years ago on Introduction
that multi purpouse oil iis from wiliksons right?? ive got some and when its empty i unscrew the top and fill it with motor oil
how did you remove your chuck?
Reply 13 years ago on Introduction
Turn the chuck as if you were opening it up for the largest diameter drill bit it can take, but just keep on turning, it'll unscrew and come away, take care to keep all the bits that fall out safe.
did it take much force?
Nope, just winds off. Can you show some pics of the chuck? I'm wondering maybe it's a different mechanism to the Stanley.
i managed to get it off by putting a allen wrench into the chuck and hitting it with a hammer it came off it sounds like yours needs tightening up
ok ill post them tonight is yours a stanly? and also its a keyless chuck and mine is not so that might be it
14 years ago on Introduction
I bought myself a hand drill this week off the market, a second hand one made by Footprint, when I got it, the thing was stiff, and the upper handle (doesn't have a side one) was split, but with a little grease on the crank, oil on the rotating parts and a quick and cheap replacement handle (lump of wood cut to size, drilled an 8mm hole in it, sanded it smooth, put it on!!!) and it works perfectly, no batteries to charge, no wires to fiddle with, it just works, so long as my arms aren't aching... :D
