Introduction: One Board Special - P51DMustang
For this years One Board Challenge I decided that I would make a model plane
There are lots of beautiful planes out there but one of my favourites is the P51D Mustang
Materials - A piece of 4x2 rescued from the skip at work
Tools - Bandsaw, drill, bench sander, table saw, dremel, elbow grease, paints and brushes
Step 1: Roughing Out the Shape
I started with my 4x2 which way way too wide so I ran it through the table saw and cut 2 10mm strips off.
one of these will become the wing and tail plane and the wider piece will be the plane body
Step 2: The Wing
I had downloaded an engineering drawing of a P51 from google and printed it on some A3, I cut out the wing shape and attached it to one of the narrower boards and trace around it.
I then cut the shape out on the bandsaw and sanded it to give the correct wing profile (very much by eye!)
Step 3: Tailplane
Similar to above I made the tailplane
Step 4: The Body/Fuselage
In a similar fashion I roughed out the fuselage from the thicker piece of wood, after cutting it out I found it was too "chunky" and needed thinning so I ran it through the bandsaw to just over finished size
It was then sanded and smoothed on the bench sander
I also tapered the rear and front down to the approximate correct dimensions of the real plane, again done by eye on the sander
Step 5: Attaching the Wing
I found that in order to attach the wing I was going to have to cut off the belly air scoop as making the space for the wing root would be near impossible otherwise, so off it came!
I then cut out the recess for the wing on the bandsaw and fitted the wing (after much adjusting with a dremel and sander
The wing was the glued into place and dowelled and the air scoop replaced (also dowelled)
Step 6: Adding the Tailplane
I cut out a slot in the tail (again with a dremel) and then filed it out so that the tailplane would fit
All gaps were filled with a mixture of sawdust and wood glue and the sanded
Step 7: Propeller
I drew out a propeller shape on the thin offcut and then sanded the blades to give a prop profile, I then cut off the nose of the plane and attached the propeller and nose back on with a piece of dowel
I also cut a couple of exhaust manifolds from the thin piece and sanded them even thinner
Step 8: Exhausts Attached
The exhaust mounts were cut out using the dremel (again) and the manifolds glued into place
Here it is shown next to a laser cut Spitfire I am working on (Bought from MakeCNC)
I was in 2 minds whether to paint it but decided to so looked up some schemes on the web
Step 9: Painting
I used some acrylic paints to paint it and the decals are spares/alternates from an airfix model
