Introduction: Onshape Trophy (Millimeters)
This is a 3D Trophy model created by onshape, if you want to make a trophy like this you can go onto onshape and follow my steps.
Step 1: Workspace Units
Step 1: Make sure the Workspace Units are set to Millimeters.
Step 2: Sketch 1
Step 2: Draw 2 Squares with the Height and Width of 18 Millimeters, then draw a trophy shaped pattern with lines on top,
Step 3: Extrude 1
Step 3: Extrude the Two squares with a depth of 35 Millimeters, and select new and symmetric.
Step 4: Revolve 1
Step 4: Select the trophy pattern you made on sketch 1 and click on the line in the center to make it revolve.
Step 5: Sketch 2
Step 5: Make a textbox and put whatever you want and extrude the width to 25 and drag fthe text from top to bottom to make it fit.
Step 6: Extrude 2
Step 6: Extrude the text you put and make sure the depth is 1 Millimeter.
Step 7: Sucess!
Now your trophy is now done!
