Introduction: Open Air Pc Case
Tools required for this project are
- Hammar
- hand driller
- screw drives
- measuring tapes
- metal cutter
- hacksaw blade
In supplies you required these items:
- uPVC pipe 1/2 inch
- T connector for 1/2"
- elbow connector for 1/2"
- 1/2" screws
- thread
- metal sheets piece
Step 1: Step 1: Cut the UPVC Pipe Into Mentioned Length
Cut the uPVC pipe in the mentioned length
- 2 piece in 430 mm
- 2 piece in 400 mm
- 2 piece in 270 mm
- 3 piece in 330 mm
- 4 piece in 20 mm
- 4 piece in 80mm
Step 2: Step 2: Connect Pieces
Using T connector and elbow and connect in.
First, take 270mm length to connect with T vertically & 400mm piece connect horizontally with the same T connector as shown in the attached figure.
Second, connect another T connector with T by using a 20mm uPVC pipe piece.
Third, connect T and elbow with each other by using an 80mm piece
Fourth, connect the elbow connector with another elbow connector using a 430mm piece.
Like that make a cuboid shown in the figure
Step 3: Step 3: Drill 330 Mm Piece of Pipe
In this step, we will use the hand driller to drill the 330 mm of pipe for the motherboard screw position and also drill the opposite side of the pipe for fixing it on the structure. You can use 2 and 3 pieces of 330mm length of pipe.
Note: using it 330 mm in length for EATX motherboard up-gradation in the future. Here I'm using mATX motherboard that's why I'm using 2 pieces of 330 mm pipe. You can change the length of pipe as per your requirements
Step 4: Step 4: Cut the Metal Sheet
Here I've cut the metal sheet by using a metal cutter & made a metal connector which I used to connect the SMPS in the case.
Step 5: Step 5: Connect Motherboard and Other Peripherals
in this step, we will connect the motherboard to the pipe by using a screw with a spacer & on the opposite side of the pipe fixed on the frame by using thread.
Step 6: Step 6: Finally Connect All the Component
Connect all the components on the motherboard like graphics card tv, tuner card, Wifi module, and last but not least Smps to the motherboard. Connect the CPU to Monitor, keyboard & mouse.
Turn on your computer & enjoy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
