Introduction: Open Hogu Project Part 1: Flex Sensors
A tutorial on how to make flex sensors
Step 1: Measure Length of Hogu
Measure the length of the Hogu as shown. This will be the length of all the flex sensors.
Step 2: Cut Velostat Material
Cut your velostat sheet into a strip about 1.5 inches wide and as long as the previous measurement. If the velostat is too short to fit the length then a second section can be cut to fit the length.
Step 3: Cut Foil
Cut out 2 strips of aluminum foil like shown above.
Step 4: Strip Wire
Take the end of some black wire and strip about an inch with scissors.
Step 5: Tape End of Wire to Foil
Use electrical tape to connect the wire to the foil. Wrap the tape all the way around the foil so that the wire cannot make direct contact with the velostat.
Step 6: Tape Foil to Velostat
Use electrical tape to attach the foil to the velostat. Make sure the foil is as flat against the velostat as possible.
Step 7: Repeat on Other Side
Repeat the previous steps for the other side of the velostat film. It is recommended that red wire is used for this step to distinguish ground from power.
Step 8: Cut the Ends
Cut the ends of the wire from the role. Leave at least 6 extra inches on top of the length needed to route the wires over the shoulders and to the back of the Hogu.
