Introduction: One Hub to Rule Them All!
About: Photographer, Climber, Programmer, Maker, and more
Home automation is a growing space and every device has it's own way to interact with it and your phone is starting to get cluttered with all the different applications for each company. The Open Smart Hub allows you combine them in one place, make new ones, and let your home handle itself based on your preferences automatically.
Imagine this you're sitting at home on your sofa and it gets way too warm due to the afternoon sun shining through your window. No need to get up, because your window begins to open by itself in order to cool it down. An hour later it starts to drizzle (a summer storm) but luckily your home hub knew that would happen and it closed your windows for you! That's just one example of what the Home Hub could do for you. The great thing about it is that you can add any device to be automated through the hub! Imagine automating your home lighting, water heaters, sprinklers, etc. based on your movement, usage, time of day, and weather. Your regular home can now become a smart home!
Step 1: ​How Does It Work?
There are three components. The online-hub, local-hub, and devices.
  • The online hub lives in an Azure web app with WebSockets turned on.
  • The local hub connects to this online hub and runs on a local machine with Node.js. It will communicate to your devices through the internet or local network.
  • The devices are your smart home devices. They can be anything from a NEST thermostat, WeMo switches, SmartThings devices, or even your own self-made projects.
Step 2: ​Get Started Using It!
