Introduction: OpenShower: Waste Ends Here
Hi, Ernesto here. What is OpenShower?
OpenShower (OS) is a fully open, modular shower system designed to save water and energy — focused on delivering the best shower experience without the need to spend thousands of dollars or modify your bathroom installation. Thanks to its all-in-one, ready-to-use design, you can build it, customize it, and repair it yourself — driven by the vision that owning a premium shower should be as simple as buying a coffee machine.
OpenShower reinvents the shower experience by eliminating invisible waste and making each session more efficient and sustainable. With a 19-liter tank, it sets a natural water limit that encourages better habits without compromising comfort. The exact amount of water is preheated and delivered instantly, reducing waste during heat-up. Automatic pressure control eliminates the need for manual adjustments, saving time and optimizing water use. The transparent cylinder shows real-time water usage, while the top display reveals insights you’ve likely never seen before.
This project has taken a lot of effort and dedication — first to develop it, then to present it clearly and concisely. That’s why I put together a GitHub repository, this Instructable, and a YouTube video to show the full build process. I tried to document 100% of the steps.
With this combination of ideas and resources, I want to show you what’s been possible so far — in a way that’s as transparent as the shower itself. (Check Step 19)
If you’d like to support the next-gen version — with features never seen before — I invite you to check out the Kickstarter campaign.
BOM FILE:
https://github.com/blanyaShowers/OpenShower/blob/main/hardware/billOfMaterials/BOM.xlsx
Each component has its own tab in the Excel file, where you can find the part and its image.
Step 1: Review the 3D Model and Available Resources
The YouTube video walks through the 18 steps to build the model, showing in detail how parts are handled, which tools are used, and extra insights only visible through video.
YouTube Video:
The 3D model includes only the 3D-printed parts and their placement to help you identify each shower component. Acrylic pipes are included in the model for reference but are not printable parts.
Fusion 360:
Colored and Dark are the same — only one has colored parts for easier identification.
GitHub:
GitHub Issues:
https://github.com/blanyaShowers/OpenShower/issues
Kickstarter:
https://www.kickstarter.com/projects/blanya/openshower-waste-ends-here?ref=24dbeq
Step 2: Print Test Fit Parts for Adjustment
Although all 6" (Acrylic Pipe OD152.4 mm - 3.0 mm wall thickness) may look similar, they often have slight diameter variations and are not perfectly circular.
For this reason, it's important to test different O-ring sizes and adapter pieces to find the best fit.
Use O-rings with a 3.0 mm cross-section in various sizes to find the best fit. The O-ring fills small gaps between the adapter and the pipe, helping to prevent glue leaks.
Recommended sizes:
OD 110mm / ID 104mm
OD 135mm / ID 129mm
OD 125mm / ID 119mm
Use the one that fits the pipe best.
Step 3: Print All 3D Parts and Get the PCB
Print the 3D parts from the repository and use the 3D model as a reference:
https://github.com/blanyaShowers/OpenShower/tree/main/hardware/3dPieces
For components that come into contact with water, use SLA (resin) 3D printing technology.
White resin tends to yellow over time with use, while black resin shows minimal discoloration.
Printed Circuit Board (PCB):
3D-printed parts and PCBs manufactured by JLCPCB
Step 4: Prepare the Pipes for Assembly
Clean the pipes and sand the edges to improve glue adhesion.
Acrylic Pipe OD 152.4 mm x L16 cm (3.0 mm wall thickness) - Electronics
Acrylic Pipe OD 152.4 mm x L90 cm (3.0 mm wall thickness) - Water Pipe
Step 5: Attach Adapters to the Electronics Pipe
Try out different O-ring sizes to find the best fit. The adapter should fit tightly to help prevent glue leaks
Before applying glue, you can apply water test to check for any leaks. It's a good idea to practice with this piece before applying glue to the main water pipe.
Use Loctite 401 a cyanoacrylate-based glue. You can use an accelerator to keep it from staining the acrylic and to save time — just make sure to apply only a small amount.
Step 6: Attach Adapters to the Water Pipe
Test different O-ring sizes for the best fit.
Align the top and bottom parts using tape as a reference. Make sure to match any screw holes from the top with those on the bottom. Proper adapter alignment is essential for smooth assembly. You can practice aligning the parts before applying the glue.
Apply Loctite 401 glue in the same gap area as used in the Electronics Pipe to securely bond the parts.
Step 7: Prepare the Main Module Base
This is an important part — it holds the heating element, two sensors, air inlet and outlet, and the main power cable.
Don’t overtighten the sensors; you could break the part. Each component should slide in with light pressure — no forcing.
Sensor threads are not included in the part. You'll need to use 1/4", 1/8", M6 and PG7 tap threads for those.
The main heating element shown in the video is 1000W 120V to ensure broad compatibility with most electrical networks. Using the 1650W or 2000W version is still viable, but it may cause outlet overheating if your electrical system isn’t prepared for that load. Make sure your setup can handle it before upgrading.
Make sure the piece Tank-Window.stl is printed in translucent or transparent material to allow light to pass through.
Step 8: Prepare the Display and Arm Support
This piece includes the pipe that goes inside the tube for water input and output, the screen mount, and the air outlet for pressure regulation.
Make sure the pipe isn’t positioned too close to the base — leaving at least 1 cm of space helps prevent water flow restriction.
Step 9: Assemble the Core System Structure
Apply a silicone gasket to ensure a watertight seal. Allow the silicone to dry for 24 hours before filling the tank with water.
Use screws to attach the top and bottom parts to the water pipe.
Step 10: Prepare the Shower Arm
This component controls the water inlet and outlet.
Adjust the height as needed, and you can even swap out different shower arms for different experiences.
It includes a check valve, a mini water filter, and the shower head.
Step 11: Prepare the Magnetic Bottom Base
The base is secured with three neodymium magnets, providing extra support by increasing the contact surface and helping to stabilize the shower.
Another way to stabilize the shower is through the top part, which has small grips that make it easier to tie the tank down and prevent any falls.
Step 12: Prepare the Power Source Cable
Cut the 12 AWG cable at your preferred length. It's usually best to place the connector away from the water tank — in my case, about 2.5 meters away.
Step 13: Present the Fully Assembled Frame
Most of the parts are now assembled, and the shower closely resembles the final product in both look and feel.
Step 14: Assemble the Electronic Components
Refer to the BOM.xlsx file for details and images of each electronic component.
Solder all electronic components and connectors to the PCB. Then plug in the ESP32, PWM module, and other components into their corresponding connectors. Once everything is in place, test all connections to ensure proper functionality.
Step 15: Load the Control Software
Using the Arduino IDE and the code from the repository, upload the firmware to the ESP32.
Also, upload the .JSON files that contain the shower profiles.
https://github.com/blanyaShowers/OpenShower/tree/main/software/firmware-ESP32
At this point, it's expected that the battery readings may show up to 120% with some erratic variations (Battery Level Readings Inaccurate #4).
Screen References:
- Water Temperature: Displays the current water temperature in Celsius.
- Shower Profile: This icon changes based on the selected profile.
- P.Bott: Measures water level before and pressure during the shower.
- Start/Pause: Displays “Start” before and “Pause” during the shower.
- Battery: Indicates the current battery level charge status.
- Bluetooth: Gray means not connected; yellow indicates a successful connection.
- Desired Temp: The target temperature for your shower.
Profiles:
With thousands of possible combinations, Profiles are your personal memory presets. They coordinate water pressure, and even light intensity and color — giving you full control with zero effort during your shower.
You can set the temperature from the app. It might also work through profile.json, but I'm still figuring out which one makes more sense.
Step 16: Integrate the Electronics Into the Frame
The electronics in the top and bottom sections are connected using an FCC cable.
Verify that all hoses are properly seated in the pneumatic fittings, as inadequate connections frequently result in air or fluid leakage.
Step 17: Run Leak and Connection Tests
Fill the tank with a small amount of water to check for any leaks. This step also helps verify basic functionality.
You can check the current water temperature, set your desired temperature, and choose a shower profile using your phone. Just install the nRF Connect app — a widely used tool for connecting to BLE devices.
Search for the BLE device named "Blanya OS V1.0" and connect.
Set Temperature
- Open the characteristic with UUID: beb7aaedc10b
- Valid values: 1 to 45
- Success: You will hear a confirmation sound or see the updated value on the screen.
- Max allowed temperature: 45 °C
Set Shower Profile
- Open the characteristic with UUID: 6412269d6f42
- Valid values: 0 to 3
- Success: The system will restart and profile icon will change.
Note: Both values must be sent as text (UTF-8 encoded).
Step 18: Perform the Final Test in the Bathroom
Thank you for following the steps!
At this stage, you should be able to take a shower using OpenShower.
If you built your unit yourself, you likely encountered some assembly challenges or identified areas for improvement. I would greatly appreciate hearing about the issues you faced, as your feedback will help improve and update this guide.
If you received a fully assembled OpenShower, this was the process we followed to deliver a fully functional unit to you.
Step 19: Blanya OS: Key Points
What is it?
An innovative, portable shower system that works with a 19-liter (5-gallon) water tank. It's completely self-contained - you don't need to modify your bathroom or touch existing plumbing.
Key Features
Water Saving
- Fixed 19-liter tank that naturally limits consumption
- Pre-heated water that comes out hot immediately
- Profile system that optimizes usage based on your routine
- Transparent design lets you see exactly how much water you're using
- See how water savings are calculated here.
Easy to Use
- Plug-and-play: ready to use straight from the box
- Customizable profiles (temperature, pressure, lights)
- LCD screen showing temperature, water level, and battery status
- Bluetooth control from your phone via ESP32
- One-button operation
Safety
- Only connects to power for heating water
- Runs on dual 18650 batteries during shower (disconnected from power)
- Built-in temperature sensor with real-time monitoring
- Electronics completely isolated from water
- Touch the tank to feel water temperature
- Operating pressure: 1 psi
Open Source & Community
- Right to Repair philosophy - print your own replacement parts
- Community-driven development and improvements
- Full transparency in design and list of materials
- GitHub: Code, bill of materials, profiles, issues
- Fusion 360: 3D models (colored and black versions)
- Instructables: Build guides
- YouTube: 18-step build walkthrough with detailed instructions
How It Works
- Fill the tank with water (hose or funnel)
- Connect to power to heat water
- Wait until desired temperature is reached
- Disconnect from power for safety
- Press the button to start showering
Benefits
- Eco-Friendly
- Significantly less water and energy consumed
- Visualize exactly how much water you use
- Encourages more conscious habits
- Heat only what you need, when you need it
Economical
- No professional installation required (Assembled Version)
- No hidden costs
- Energy bills
- Replaceable/upgradeable modular components
- Most parts are 3D-printable
- Standard, universally available non-printed parts
Unique Experience
- Illuminated bubbles with colored LEDs creating ambient lighting
- Transparent tank to see water quality and usage
- Relaxing bubble sounds for spa-like atmosphere
- Light colors could change with pressure stages
- Sensory Shower
Technical Specifications
- Tank Capacity: 19 liters (5 gallons)
- Batteries: 2x 18650 (automatically charge when connected to main power).
- Heating Power: 1000-2000W - 120V
- Connectivity: ESP32 Bluetooth with app support
- Display: 1.28-inch round LCD (watch-style)
- Sensors: Pressure and temperature sensors (expandable)
- Shower Arm: Standard 82cm (customizable)
- Weight: ~5 kg with packaging
- Materials: Mostly 3D-printed
- Working Principle: Pressurization
- Water flow range: 1.3–1.8 L/min
Display Information
- The LCD shows real-time data:
- Current water temperature
- Selected shower profile
- Water level/pressure readings
- Start/Pause status
- Battery charge level
- Bluetooth connection status
- Target temperature
Availability:
- DIY Kit: For makers (requires soldering, gluing, assembly)
- Full Assembly: For early adopters (prototype stage)
Important Notes:
- Status: Prototype
- Independent project
- Focused on makers and early adopters
- Community support through GitHub
Bottom Line
Blanya OpenShower is an open-source, portable, smart shower that revolutionizes water usage through transparency, customization, and community-driven innovation. It offers a complete shower experience anywhere without installation, while promoting water conservation and providing a spa-like, personalized experience through profiles, ambient lighting, and real-time monitoring.
Perfect for: Makers, early tech adopters, eco-conscious users, and anyone wanting shower independence without bathroom modifications.
Alternative Names: Personal Shower, Single Shot Shower, QuickShot Shower
Step 20: Conclusion
What began as a hobby gradually took over more of my time, as I spent countless hours designing every component to be modular, multifunctional, and repairable. Every detail is crafted to deliver a unique, immersive experience through parts that work seamlessly together and are built from accessible, widely available materials.
Once you dive into OpenShower, you’ll discover a project with many layers — shapes, materials, code, and concepts still waiting to be explored. It’s not just a water container. It’s also a container for code, art, creativity, and new ways to rethink our shower experience.
Soon, you’ll realize that bathing with a product you can build and shape yourself is a great experience — and that your best ideas for improving it will come while you're using it. Your shower becomes your new creative space.
There are still a few details to refine, but the system is fully functional and ready for real-world testing.
Because the best ideas come in the shower.
Crafting the ultimate shower experience — Ernesto
