Introduction: Opencv Face Detection,Training and Recognition
OpenCV is an open source computer vision library which is very popular for performing basic image processing tasks such as blurring, image blending, enhancing image as well as video quality, thresholding etc. In addition to image processing, it provides various pre-trained deep learning models which can be directly used to solve simple tasks at hand.
for opencv installation use this link
Step 1: Detecting Face in a Real Time Video
you can search google for many face detection programs and the detected faces should be saved in a folder for further image processing things like training and labeling. we are going to collect 30 samples
import cv2
import numpy as np import os import sys
camera = cv2.VideoCapture(0)
faceCascade = cv2.CascadeClassifier("haarcascade_frontalface_default.xml") #add your harcascade file path
name = raw_input("What's his/her Name? ")
#all the files will be saved under Users/prasad/Documents/images folder
dirName = "/Users/prasad/Documents/images/" + name print(dirName) if not os.path.exists(dirName): os.makedirs(dirName) print("Directory Created") else: print("Name already exists") sys.exit()
count = 1
#we are going to collect 30 samples while count < 31: # for frame in camera.capture_continuous(rawCapture, format="bgr", use_video_port=True): ret,frame = camera.read() if count > 30: break # frame = frame.array gray = cv2.cvtColor(frame, cv2.COLOR_BGR2GRAY) faces = faceCascade.detectMultiScale(gray, 1.5, 5) for (x, y, w, h) in faces: roiGray = gray[y:y+h, x:x+w] fileName = dirName + "/" + name + str(count) + ".jpg" cv2.imwrite(fileName, roiGray) cv2.imshow("face", roiGray) cv2.rectangle(frame, (x, y), (x+w, y+h), (0, 255, 0), 2) count += 1 cv2.imshow('frame', frame) key = cv2.waitKey(1)
if key == 27: break
#camera.release() cv2.destroyAllWindows()
Step 2: Training Your Sample Images
After Face Detection was completed then we can go for training the images
import os
import numpy as np from PIL import Image import cv2 import pickle #import serial#ser = serial.Serial('/dev/ttyACM0', 9600, timeout=1)
faceCascade = cv2.CascadeClassifier("haarcascade_frontalface_default.xml") recognizer = cv2.face.LBPHFaceRecognizer_create()
baseDir = os.path.dirname(os.path.abspath(__file__))
#train the images under the images folder imageDir = os.path.join(baseDir, "images")
currentId = 1 labelIds = {} yLabels = [] xTrain = [] #ser.write("Training.....".encode())
for root, dirs, files in os.walk(imageDir): print(root, dirs, files) for file in files: print(file) if file.endswith("png") or file.endswith("jpg"): path = os.path.join(root, file) label = os.path.basename(root) print(label)
if not label in labelIds: labelIds[label] = currentId print(labelIds) currentId += 1
id_ = labelIds[label] pilImage = Image.open(path).convert("L") imageArray = np.array(pilImage, "uint8") faces = faceCascade.detectMultiScale(imageArray, scaleFactor=1.1, minNeighbors=5)
for (x, y, w, h) in faces: roi = imageArray[y:y+h, x:x+w] xTrain.append(roi) yLabels.append(id_)
with open("labels", "wb") as f: pickle.dump(labelIds, f) f.close()
recognizer.train(xTrain, np.array(yLabels)) recognizer.save("trainer.yml") print(labelIds)
Step 3: Recognizing Faces
after the training was over now you can run the below code so that it will start recognizing your trained faces
import os
os.environ['PYTHONINSPECT'] = 'on' import cv2 import numpy as np import pickle #import RPi.GPIO as GPIO from time import sleepwith open('labels', 'rb') as f: dicti = pickle.load(f) f.close()
faceCascade = cv2.CascadeClassifier("haarcascade_frontalface_default.xml") recognizer = cv2.face.LBPHFaceRecognizer_create() recognizer.read("trainer.yml")
font = cv2.FONT_HERSHEY_SIMPLEX last=''
#for frame in camera.capture_continuous(rawCapture, format="bgr", use_video_port=True): while True: ret,frame = camera.read() gray = cv2.cvtColor(frame, cv2.COLOR_BGR2GRAY) faces = faceCascade.detectMultiScale(gray, scaleFactor = 1.5, minNeighbors = 5) for (x, y, w, h) in faces: roiGray = gray[y:y+h, x:x+w]
id_, conf = recognizer.predict(roiGray)
for name, value in dicti.items(): if value == id_: print(name) cv2.putText(frame, name, (x, y), font, 2, (0, 0 ,255), 2,cv2.LINE_AA) if name!=last : last=name if conf <= 70: cv2.rectangle(frame, (x, y), (x+w, y+h), (0, 255, 0), 2)
if key == 27: break cv2.destroyAllWindows()
